Question about GE WDSR2080D Top Load Washer
GE washer timer knob
Timer knob will not turn timer. It will pull out and in but won't turn thr timer. The timeer can be turned using the ring behind the knob and will then operate normally.
  • Anonymous Oct 10, 2008
    after washer fills....starts washing...then immediately starts to pump the water
    out of tub
  • Anonymous Dec 07, 2008
    I need to remove the timer knob on GE washer, what is the strategy? Space is very narrow to get needle nose in to hold in place.
I can not set the timer on my GE washer. The knob just turns with out stopping.
Posted on Dec 20, 2009
  • 178 Answers
Usually, if you pull the knob off of the timer assy, you will see in the that knob a "KNOTCH" that is used to align the knob to the timer. That could have been stripped out. Check that first.
Posted on Mar 16, 2008
The dial to select wash cycle (GE top load washer) seems loose. It is difficult to turn, as if something is not engaging. Any suggestions?
The knob wears out and won't grab. It is easy enough to replace if you know the trick. Take pair of tweezers and remove the clip behind the knob, just push on the replacement knob and oil the timer then move the timer around several times to help the shaft turn easier.b8e8a25.jpg
May 02, 2010 | GE WBSR3140DW Top Load Washer
Kenmore washer Model # 110.26852504 Cycle control knob?
You gotta pull out a rod behind the timer and that releases the knob.351bd46.jpg The rod when pushed into the timer spreads the shaft and holds it on there. To get to the innards you gotta flip up the controls. I have a cool video that shows how
Mar 12, 2010 | Washing Machines
Can't remove control timer knob on kitchenaid washer
The shaft go'es all the way thru the timer on most and you can keep it from spinning there.
Oct 16, 2017 | KitchenAid Washing Machines
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Wash cycle knob turns without controlling wash cycle
it's possible go to and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Apr 06, 2009 | Washing Machines
Control knob will not turn to desired setting
the timer knob has a clip that will allow you to remove the knob from the timer. it is between the knob and the dial. what happens is the knob has gear like teeth that will become stripped is easy to replace but alittle hard to remove. you need to get a small screwdriver and go behind the knob, pull on it alittle and you will see the clip, then use the screwdriver to push the clip out of the knob, then the knob will pull of and you can replace it.
Dec 28, 2008 | GE WJRR4170E Top Load Washer
Timer switch on GE washer
You don't state your exact model number, and the number off the timer is not the actual part number (it's some sort of part stamping number). Most likely what has happened is a plastic tab on the timer housing (which normally goes into a slot in the metal, and thus holds the timer at that point) has broken off. The fix is to replace the timer, but instead of buying a new timer, I usually fashion a Z type piece of metal which I can put one screw though into the metal and the other side holding the timer against the metal. Takes a little work, but it's a lot cheaper than a new timer.
If you want to take the timer knob off, you have to pull it out and use a thin tool, like a small screwdriver, to push the plastic clip off the shaft behind the knob, allowing the knob to then come off the shaft. Push the clip back on the knob when off, so that all you have to do to reinstall the knob is push it on and it will lock on the shaft again.
Dec 08, 2008 | GE WBSR3140DW Top Load Washer
Timer Knob
The clip pulls straight up off the shaft directly behind the knob. You can use a small screwdriver or a pair of needlenose pliers to pull it out. Once the clip is removed the knob will slide off the timer shaft.
Apr 21, 2008 | GE WDSR2080D Top Load Washer
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE WDSR2080D Top Load Washer Logo
2,010 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
