FixYa.com
Tags:
Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
DVD problem with Toshiba TV/VCR/DVD Model MW24FP1 (by 3 users)
posted by barkleys on Mar 04, 2008
Everything worked fine until one day the DVD started making noise like a belt grabbing when you try insert/remove a DVD. Also happens when you turn it on or off. The DVD tray won't stay in, once it goes in and starts making the noice it ejects. TV won't stay off because the DVD is trying to stay in and can't. Took off cover but you can't really see inside the DVD player.
Thanks
Comment by barkleys, posted on Mar 05, 2008
Now have a "new"/secondary problem. Put a little Zep spray (industrial strength WD40) on the gears that drive the drawer in and out. Now it open and closes with no noise and does not reject the tray but now it won't read a disc. Getting a message that says "incorrect disc". Does it sound like I got something on they eye? How can I clean it? Did I finish it off for good? :0)
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by thomas156, posted on Jun 09, 2008
i tried to play a vhs tape in and herd a belt grabbing sound i tried to clean out the vhs component system and i still have the same problem with the same result
Comment by indjazz, posted on Mar 11, 2008
I too am waiting for a solution to the problem of the noise the DVD player is making.  Mine went out after only a year.  Is there any way to bypass the internal DVD and hook up an external?  I have tried but it does not seem to work. Any ideas?
Thanks
Solution #1
posted on Apr 04, 2008
Not Rated (0)
jkitty
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these TV Combos problems?
TV Combos
2 week old dvd/tv makes loud...
week old dvd/tv combo second... Answer This...
MW24F11 will not turn on
The TV will not turn on either... Answer This...
The tv turns off when I connect...
One day I moved the TV to a... Answer This...
Toshiba MW24FM1 has lines...
Toshiba MW24FM1 has lines... Answer This...
there are a few lines across...
can still see the picture but... Answer This...
Repair Service
Find TV Combo Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
