Question about LG 32LX1 32 in. HD-Ready LCD Television
LG 26LC55 32inch LCD
Its my first LCD.
I am losing all dark definition at an angle just below the horizontal when viewing.
Is this normal.
Have adjusted brightness etc but no good
  • Johnny Gall Mar 04, 2008
    are manufacturer angles of distortion available - the one i suffer seems extreme at about 15 degrees below the horizontal
    Cheers Sids
  • 61 Answers
Yes all lcd's, for that matter tv's have viewing angles ..What you are experienceing is normal
Posted on Mar 04, 2008
  • Sid B
    Sid B Mar 04, 2008
    should be in your instruction manual..below the horizontal plane dose not have much tolerance...
KDL-55XBR8 every 6th horizontal line is dark to the left and gets normal to the right
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 26, 2014 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
When viewing from below tv the screen is dark
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Mar 27, 2014 | Panasonic Televison & Video
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Astromaster 76 image 45 degrees off horizontal, although eyepiece set at same angle for comfort of viewing .how can i keep eye peice set and see image correctly i.e 90 degrees from horizontal
    All astronomical telescopes show upside down images. It's normal.
    However, you can buy and erecting diagonal like the one below for terrestrial viewing.
    http://www.amazon.com/Orion-45-deg-Correct-Telescope-Diagonal/dp/B0000XMYEW
    Jan 30, 2011 | Optics
    I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
    hi,
    these are the specs for you monitor
    Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
    Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
    By law, California shipments of this product are subject to an $8.00
    Electronic Waste Recycling Fee
    Features/Specifications:
    • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
    • General Features:
    • Silver Cabinet color
    • 19" diagonal screen size
    • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
    • Compatible Modes: VGA, SVGA, XGA, SXGA
    • Contrast Ratio: 600:1
    • Brightness (Nits): 300 cd/m2
    • Response Time: 21 ms
    • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
    • Built-in stereo speakers
    • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
    • DC Input: 19V - 3.1A
    • EnergyStar compliant
    • Regulatory Approvals:
    • FCC
    • UL
    Package Includes:
    • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
    • Power Supply (100-24V 50~60Hz)
    • Power Cord
    • Stand
    • VGA cable
    • Audio cable
    • User's Manual
    Additional Information:
    • Requirements:
    • Available power outlet
    • VGA adapter
    • Notes:
    • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
    • 17-Inch to 18-Inch:
    • Total Defects: 8
    • Bright or Dark Dots (random): 4
    • Bright or Dark Dots (2 adjacent): 2
    • Bright or Dark Dots (3 adjacent): 0
    • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
    for the adapter, already inserted the picture of it
    Hope this will help... Your response is very much appreciated....
    Jan 20, 2011 | Computers & Internet
    My Dell monitor developed a thin, dark line horizontally across the screen. Within three months, a second line appeared. I can view the screen, but must look above or below the lines at times. Any idea...
    this occurs very commonly in all LCD monitors... this is because each and every cells in the LCD monitor are energized by the vertical and horizontal electric fields placed around the frame of the monitor... if a particular field does not gives the power to the associated cells to it, then the entire line of cells will not operate and together they looks like a single line...This is what happened in your case...
    have a look at my tips for replacing the LCD screens on monitors, by clicking here....
    Aug 11, 2010 | Dell Audio Players & Recorders
    My LG monitor having few problem, 1.few dark shade showing on top left and right corner. 2.though monitor brightness is 100% but not showing properly.
    Most LG monitors use TN panel. These panels have a very limited angle of viewing so when viewing up close or from a side the image will be degraded. This is how the monitor normally works, there's nothing you can do to make it better.
    Aug 03, 2010 | Computers & Internet
    How can I restore factory settings on our LG Flatron LCD Monitor?
    press menu button it is in middele of lcd.
    Ten go to setigns and u can fine reset buton press ok.
    Jun 13, 2009 | LG L1730S 17" LCD Monitor
    LG L1717S has no light
    Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
    Apr 23, 2009 | LG L1717S-BN 17" LCD Monitor
    LG 32LX1 32 in. HD-Ready LCD Television Logo
    160 people viewed this question
    Computer Repairing
    Computer Repairing
