Question about Bosch HES436U Electric Kitchen Range
Bosch convection oven
I have a convection oven (3 rack) that was purchased in Nov 2004. Just lately, when setting the oven to preheat it will get close to the temperature after what seems to be a LONG time, but won't quite get to the temperature selected. When I opened the door to put in biscuits on Sunday, (temp was 370 for a 375 setting), the temp plunged 30 degrees and then, according to the digital read-out, continued to drop another 15 degrees over the several minutes instead of heating up again.
Can you tell me where to find an approved repair person in the Hanford, CA area?
Thank you for your assistance.
Phyllis
3 Suggested Answers
SOURCE: Bosch HES255U Covection bake slow to get up to temp.
My Bosch HES255U Freestanding Electric Range has been reading an error code of all "E's" or r 2 E E. I shut it off completely through the circuit breaker and allow it to reset. When I turn it back on, it starts to beep and shuts off.
Posted on May 03, 2010
  • 180 Answers
SOURCE: The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Posted on Jan 30, 2011
When using oven it beeps twice and oven light comes on and oven shuts off
[PDF]Bosch Hbl8650uc Use And Care Manual - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../bosch-hbl8650uc-use-and-ca...
foods with the appropriate oven mode, temperature, rack position and bake time. This section also ..... Preheat. Light. Lower. On/Off. Upper. True. Convection. Speed. Convection. Broil. Bake. Roast .... Cook Time: Turns off beep for the end of cooking time. •. Timer: Turns off ... Press Timer twice to exit the timer menu. Note: •.
PDF]Use and Care Manual for Bosch Electric Built-in Single ...
pdfstream.manualsonline.com/.../9d658fa3-efaf-44a3-beb6-bc5f9c80d5...
realize the full potential of your new Bosch oven as well as protect it from damage ..... On/Off light. • Heat light. • Door lock light. • Timer/Manual selector knob .... the display will come on showing all the call-outs, .... Electronic Control of Oven. Immediate. Start/Automatic. Shut-Off. To use the .... Depress Cook Time button twice.
Dec 02, 2015 | Bosch HDI7152 Stainless Steel Dual Fuel...
I just bought the microwave/ convection oven 800 series. Do I have to take the rack out when I use the microwave, and the turntable out when I use the convection oven?
No you do not have to remove anything. The rack is made to be in there. If you still are not sure look in the owners manual or call the place where you bought it. I have a combo oven/ microwave also and can use one or the other or both at the same time
Mar 01, 2015 | Bosch Benchmark Series HMC80251UC 30"...
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
My bosch convection oven is not heating up. It is stuck at 100 and the display is moving between preheat and bake.
I had the same problem and I replaced initor (part number 492431). It is working now. It takes 5 min to replace it.
Nov 16, 2010 | Bosch HGS 255 Gas Kitchen Range
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
Jan 17, 2008 | Bosch HBL 745 Stainless Steel Electric...
Temperature problems in Bosch range
I would check to make sure you are using a 220 plug.
Jan 09, 2008 | Ovens
Bosch HES436U Electric Kitchen Range Logo
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
