Question about GE 24 in. Profile PDW9280JSS Built-in Dishwasher
Problem with GE Profile Dishwasher
Control panel on top of door does not light up when power is applied. Also a high pitched sound is continuously emitted - I shut power off to reset the control panel. Turned power back on, same situation - no lights and high pitched sound. Any help would be greatly appreciated.
  • 4 more comments
  • RFS170 Mar 25, 2008
    I got the same problem (no lights on the control panel) .When i close the DW it beeps...some settings are on and it will only start if i use a flat item to press the Start button. (no idea what the setting is but one of the heated lights are on.
    thjis problem happened when we got 2 short power outage within 5 min.
    I have turned off power to DW at the main electric panel. did it with intervals of 2 min/10 min/2 hours/12 hours and finally 24 hours( I was desperate for it to work)
    The dishwasher goes through a whole cycle , like I said before by pressing Start with a flat silverware, so in a way it works ...but not how it's supposed too..i am thiking control panel got fried ??? HELP !
  • sabraun1 Sep 07, 2008
    I have replaced the control module and this did not fix the problem. The display does not light at all until you shut the door. At this point it beeps and you con see some lights on. It will run for a short time then guit.
  • capecodsusan Dec 23, 2008
    I have the same problem, same situation (happened after a power outage), and the same solution (using a flat object to operate the start button when the door is closed). I just had a technician come out today and I'm not convinced he knows the solution. He told me it is either the keypad or the electronics that need to be replaced--Estimate was about $350.
  • Anonymous Jan 06, 2009
    I have a similar problem. The time delay button does not work and then dishwasher is stuck on Antibacterial setting. I have tried to turn off the power at the breaker with no help.
  • lindaosterlu Mar 30, 2009
    I have this problem. It was beeping randomly throughout the day, then on the control panel all the selections light & beeps work, but the START/RESET button does not light or beep or turn anything on...HELP
  • Anonymous May 24, 2009
    same problem no lights and a constant tone.
Thank you so much to Capecodsusan. I used a flat object on the start/reset button and it is working fine. A little bit of a hassle, but it is working.
Posted on Feb 08, 2010
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Posted on Jan 27, 2010
The start light is not coming up
washer has high pitching sound with no power setting lights on
May 10, 2012 | GE 24 in. Profile PDW9880JSS Built-in...
I have a newer model GE dishwasher. About a couple of weeks ago we lost power to home. When power was returned the dishwasher was making a high pitch sound and power was not returned to the front...
Hello
High pitch sound comes when the main control also known as the electronic board goes bad and needs replacement. Please try to blow air with hair dryer on the display just to check if that'll solve the problem. Hope you understand...If it does not then replacement of part is only recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Aug 11, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
My dishwasher makes a humming sound and has no lights on the control panel.It stoped and will not respond to any command
wiggle the door latch sometimes they get a little corrosion in the door switch and dont respond to the door being closed
Jul 26, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Power outage occurred. Upon power back on Dishwasher has high pitch tone and no lights and it will not do anything but make sound.
A power surge has occurred unfortunately. this surge has fried the control module and, you will need to replace this module asap.
I would check the motor as well. it may have took a hit as well. test the continuity of the element as well.
Jun 02, 2009 | GE 24 in. PDW8800J Built-In Dishwasher
Electricity went out last night. when i get up this morning, it is making a high pitch squeeling noise and now none of the buttons work????? its a ge profile dishwasher
The electricity probably "surged" when the power came back on. It sounds lke the conrol board may have "fried". Call the repairman and get an estimate.
Mar 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
GE ZBD6880KOOSS
This is an unusual failure. The humming could be a motor (or valve) that has power but isn't moving. But that doesn't explain the (absence of) lights on the control panel. I suggest you call a professional.
Mar 31, 2008 | GE Monogram® ZBD6880NSS Stainless Steel...
High pitched whine
I have the same problem. Replaced the module and still a continous beep....
Dec 28, 2007 | GE 24 in. Profile PDW9880JSS Built-in...
GE 24 in. Profile PDW9280JSS Built-in Dishwasher Logo
2,384 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
