This should help any further assistance please feel free to contact me.
WHIRLPOOL Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition
Check/Repair
4 Digit Failure Code
F0 - E0
Analog to Digital Failure
Disconnect for 30 seconds - if display re-appears - replace control
F1 - E1
Safety flip flop
Replace Electronic Range Control/Clock (ERC)
F2 - E0
Shorted keypad
F3 - E0
Oven temperature sensor or oven temperature sensor fuse opened
Replace oven temperature sensor or fuse
F3 - E1
Oven temperature sensor shorted
F3 - E2
Oven too hot
F3 - E3
Clean temp too hot
F5 - E0 F5 - E1 and E2
Check door/latch switch
Replace component
2 Digit Failure Code
F0 or F1 or F5
Failed transistor
F2 - E0
Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
F3
Open oven temperature sensor or thermal fuse
Replace oven temperature sensor or thermal fuse
F4
Shorted oven temperature sensor
F6
Problem in time keeping circuit
1. Reset time and/or cooking operation
2. Check for proper ground
F7
Stuck function switch or button on Electronic Range Control (ERC)
Replace ERC (Electronic Range Control/Clock)
F8
Failure Electronic Range Control (ERC)
F9
Door lock circuit
Check wiring and test operation of door lock switch
WHIRLPOOLRange/Stove Oven Fault Codes, Common
Failure
Code
Condition
Check/Repair
Digit Failure Code2
F1
Disconnect for 30 seconds - if display reappears - replace control board
F1
Safety flip flop
Replace board
F1
Shorted keypad
Replace keypad
F3
Oven temperature sensor opened
F2
F3
Oven too hot
F3
Clean temp too hot
F5
Replace switch if defective
F1 - E1
Safety flip flop
Replace board
F2 - E0
Shorted keypad
Replace keypad
F3 - E0
F3 - E1
F3 - E2
Oven too hot
F3 - E3
Clean temp too hot
had a power surge and clock displays a F! error code and beeps constatnly, stove and oven are working but still beeps.
