My monitor W2043T went into analog power saving mode all of a sudden and i checked VGA cord and also the ram it dint work too i changed the monitor and restarted still its the same..
Hi, that message indicates that your video source is providing an unsupported video resolution , please check in settings that video output resolution is no more than 1920 x 1080 @ 60Hz.
Also remember to verify that HDMI is selected as input source at monitor.
Try connecting the monitor to a friend's computer. If you get some sort of a display it's not the problem. When you say that the computer makes a new noise like the fans are spinning fast, you might have an issue with the video card , motherboard, or power supply.
If its going to analog power saving mode, that is what its supposed to do when it does not get a recognizable connection from a computer vga port. I would suggest coming back on with some more information about your computer and suggest testing another screen on your pc.
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Check the VGA cord that connects from the PC to the LCD, try putting VGA
cord properly to the LCD and PC, or change the VGA cord. saving mode
indicates no signal from the PC. So either the PC is not booting up or
VGA cord faulty.
The monitor doesn't receive the signal from the PC. It is either the PC
not booting up or the VGA coard is faulty. Change the VGA coard. or try
reseting the VGA cord.
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'.
Click on 'Power' then Power schemes tab.
Look at 'Turn off monitor' and set to 'Never'
