Riso rz 370 ep printer paper is not smoothly fed from the paper feed tray
It keeps jamming.
have adjusted the paper feed pressure adjustement lever to the corresponding paper but still no effect.
i tutn the stripper plate angle to all direction till I find the sorrect position but still to no effect
pls advise as soos as poosible
  • 1 more comment
  • roshini Mar 04, 2008
    pls could you answer or advise on following email ID
    explorer2.radio@super-hub.com
    or ravi4chippu@yahoo.co.in
    still awaiting yr great advise
  • mskbelle Mar 07, 2008
    After a year abd one month, my HP Photosmart 3180 ja,,ed at printing. I cleared the jam, but it keeps drawing the paper at a slight angle. I have straightened the paper to the guides, made sure there wasn't too much or too little paper, re-booted, etc., to no avail. Naturally, this happens after warrantee... What do you suggest???
2 Suggested Answers
nancy85830
  • 4 Answers
SOURCE: riso rz 370
if show P96172 it means that have to adjust the scanner
Posted on Aug 11, 2009
Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Jul 25, 2008 | Riso RZ220 Duplicator
We have a gr 3750 and when the paper tray comes up the feed wheels do not start up to feed the paper in.Any suggestions
  1. check the upward sensor for adjustments and the sensor on the stripper pad unit for adjustments
Mar 13, 2011 | Riso Office Equipment & Supplies
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Our school owns a Riso RZ machine and theirs a problem with it; the code is A-06 it also has this -403. Could you please help?
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
E-mail me; nambwex007@yahoo.com
Jan 04, 2011 | Riso RZ390 Duplicator
Problema para Riso - Duplicadora RZ220 Copiadora Error message A-06-403 Mensaje de error A-06-403
where can i find the Riso RZ Paper-feed-tray upper or lower safety switch
Aug 09, 2010 | Riso RZ220 Duplicator
Hp laserjet P4515n printer
you'll probably need a replacement paper tray.The sliders are fitted with small teeth to prevent them from moving.These teeth can break off meaning the paper size slider moves around too much and the paper sits back away from the feed roller and it doesn't get picked up correctly by the fed roller so resulting in a paper jam error
Oct 12, 2009 | HP Office Equipment & Supplies
Brother Laserjet 8860dn printer not picking up/feeding paper
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
To check, press the purple lever at the right front of the tray. The leading edge of the stack of paper in th etray should rise out of the tray so that the top piece of paper can be fed into the drum assembly. If the stack does not rise evenly, or will not rise, the rear adjustment is the problem.
You can inspect the springs in the paper tray by removing the plastic cover that is above the white translucent roller in the tray. To do this turn over the tray and release the catches with a little screwdriver. I do not think there is a missing spring. While you have the cover off clean the lnt from behind the roller.
Oct 01, 2009 | Brother MFC-8860DN All-In-One Laser...
Paper feeding problems Riso TR1510
refix your ink cartrdige also check there is not any paepr jam issue.
also some times printer neeed servicing creates this type of issue.
Mar 28, 2009 | Riso Office Equipment & Supplies
Riso rz 370
Mar 10, 2008 | Brother MFC-440CN InkJet Printer
1,452 people viewed this question
k24674
jasbo
jasbo
