error 011 normally means the paper cassette is not fitted properly. Usually the cassette(paper tray) sensor is out of place or the cassette is damaged.
If the "Mode" was "Tx" or "Snd", you tried to send a fax,
and the other fax machine did not answer, then it was either turned
off, or out of paper or ink. If the mode was "Rx" or "Rcv", it means
your fax machine tried to receive a fax, but none was sent. If your
machine was in TEL/FAX or FAX mode and it received a regular call, the
caller heard the fax tone and hung up. If your machine was in ANS/FAX or
EXT.TAM mode, it most likely means a regular voice caller heard the
answering machine and hung up without leaving a message.
you broke the tab on the back of the paper cassette. if you look in where the cassette goes on the back left you will see a hole with a sensor that looks kinda like a upside down letter U . put paper inbetween the sensor and the machine should say out of paper and put the cassette back and you should be fine
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
1 On the end of the paper cassette is a broken off tab. Turn the machine on it's back. You will see a black u-shaped photo sensor that this tab goes into. Stuff a small piece of electrical tape in there.
2. Press Function/ 7/ monitor key slowly 4 times/ star/ 6 scroll down to shipment set/ 2/ press set (fax will reboot)
