Regarding ASP.net i need to knw how to retreive datas from db and display it in aspx page when i click search command.......
    Sergeant:
    Champion:
  • 310 Answers
This web site will help you
http://www.academictutorials.com/
Posted on Mar 04, 2008
No updates just error 646
Hi
This problem usually occurs with vista operating system.
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%System32Catroot2 Catroot2.old
ren %systemroot%SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043” and install it.
Visit the following link to download the update: http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en
Restart the computer once the update is installed.
Hope this solves your problem
Dec 17, 2009 | Microsoft Computers & Internet
I cannot download the new windows updates-I get an error message 646 and cannot find out what that means
net stop wuauserv
net stop bits
net stop cryptsvc
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
net start wuauserv
net start bits
net start cryptsvc
and install it.
Let me know if this worked.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
Asp.net 1.1 forms in IE 8.0
On the computers using IE8, click on Page -> Compatibility View Settings. In the dialog box, enter the domain of the website using your ASP.NET 1.1 pages and click on the Add button. Now, the pages will be rendered the same way they were with IE7 which should solve your issue.
Jul 10, 2009 | Microsoft Computers & Internet
Sir how to set a messagebox in vb.net
To display a MessageBox:
MessageBox.Show("This is your messahe text!", "Title of Your MessageBox", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
Regarding connecting to an Oracle database, you'd have to search for the connection string.
Feb 15, 2009 | Keystone Active Server Pages (ASP)/Visual...
Asp.Net
about the dynamic forms/pages, u can use sessions in asp.net C#, theyre very easy to use and try using commands like server.transfer and respond.redirect in ur code. for the connectivity thigee u asked, :) m sorry my friend u cant get it like a pan cake, u gotta study w3schools odbc connectivity in asp.net tag for this :P
Dec 21, 2008 | Microsoft ASP NET WEB MATRIX (583797)
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
Problem of creating the master page in asp.net vb
Hi galondhe
I'm sorry It's not that clear what your problem is.
In Dreamweaver you save the page as a template which you can then apply to subsequent pages. Are you creating the asp.net page with all the data in it, then saving as a template?
Visual web developer uses master pages. You can always create the page in Dreamweaver and then take it into VWD to create your master.
I need a little more info to be able to help you.
Apr 02, 2008 | Macromedia Dreamweaver MX 2004 for PC, Mac
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
