Question about Toshiba Satellite U205 Notebook
Toshiba satellite u205-s5044 - fan running continuously-new motherboard
I just pick up the notebook yesterday from having a new motherboard installed. All is well, but the fan won't stop running. Any ideas what this could be? I'm going to contact the repair company, but I'd like to go in armed with some knowledge.
Thanks!
  • Kempo Mar 04, 2008
    Thanks for the reply lenny. If there's no fan, could it be the hard drive? Something with a high pitch is most definitely running.
  • 133 Answers
I don't think that they normally have a fan.
Posted on Mar 04, 2008
Where are the jumpers for bios
Do not waste your time looking for a CMOS battery or jumpers to reset password, it will not work. The solution is to take or send the laptop to a Toshiba service Center and have the password erased or reset. You may have to show proof of ownership of the laptop and you will have to pay for the service if the laptop is out of warranty.
Aug 15, 2012 | Toshiba Satellite U205-S5044...
Where can I find a schematic or instructions to open my toshiba satellite u205-s5067 laptop. I want to clean/replace my fan.
Taking apart a laptop to change the fan is a relatively simple task. Just keep track of where all the screws go and follow these steps:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Satellite U205-S5067 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Satellite U205-S5067 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Satellite U205-S5067 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Satellite U205-S5067 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Hope this helps.
Apr 05, 2011 | Computers & Internet
Toshiba U205-S5002. From PC to inverter is 9 pins. What U is on this pins? Thanks.
I was install the os window7 for new ssd in my laptop but unfortunatly was not install and reback my old hard drive install but then after i turn on the laptop but screen was not start.
Dec 22, 2010 | Toshiba Satellite U205-S5002 Notebook
How to clean up cooling fan?
Take a look at this guide:
How to disassemble Toshiba Satellite U205/U200
Take a look at the page 4. It shows how to access the cooling fan.
Nov 15, 2010 | Toshiba Satellite U205-S5034 Notebook
Driver toshiba satellite SA 1870 160c/4
Thank you for contacting the experts. I have the drivers you requested listed below. I trust this was helpful and thank you for contacting the experts.
http://www.drivershq.com/Drivers/Toshiba/Satellite/U205/4183/9941/24866/Drivers.aspx
Jan 18, 2010 | Toshiba Satellite U205 Notebook
Hello. I have Toshiba Satellite U205-S5034
Yes, this is replaceable. However, it is not easy to do and requires taking the motherboard out of the laptop and decent soldering skills. If your laptop is under warranty, consult the manufacturer and they may replace it for free. If not, computer repair places can do it for around $100 or so I believe. It is expensive due to the skills and time required.
Sep 23, 2009 | Toshiba Satellite A105 Notebook
Sound to my laptop a toshiba U205 will not work what can i do
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp# you can find drivers for your modle here, theres like 5 of the u205's so youll have to look on your lappy or the box it came in to see what one of the many it is =D hope you find um. hit downloads to pick lappy then kind you have, look thou the like 5 pageis of drivers and hopefully youll find um =)
Jun 11, 2009 | Toshiba Satellite U205 Notebook
I need audio drivers for my laptop
Have you tried the Toshiba web page? under support and drivers?
Mar 07, 2009 | Toshiba Satellite U205 Notebook
Disassembly to replace fan
I know I am too late but I just changed the fan in my U205-S5002. I couldn't find instructions anywhere so I decided to give it a try. It is very easy.
First remove all the screws below the laptop. There is only one small cover below the laptop. Remove the cover and disconect the Hard Drive. Now remove the plastic strip right above the keyboard by using a flat small screwdriver. Do not be afraid, you'll not break it. After removing the strip you will see 2 S3 screws. Remove them and the keyboard will be free to move. In order to remove the keyboard you'll have to disconnect a couple of connectors, by lightly pulling first the plastic stoppers (colored brown) out. After you have removed the keyboard you will see the fan in the upper left corner. Remove the 2 screws holding the fan and disconnect the connector (pay attention to the way the plug or the female goes in: the holes are on top). Installing the new fan is a piece of cake and so is putting everything back.
I hope this helps.
Jul 24, 2008 | Toshiba Satellite U205 Notebook
Toshiba Satellite U205 Notebook Logo
257 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
