Rapid movment of cursor
Cursor movment is very rapid and oversized? dont no how to reduce cursor size
  • 133 Answers
To reduce speed, click on start button in windows
allprograms,
control pannel,
select printers and other hardware,
mouse,
carry out the changes u want by reading through the dialog box. when finished click ok
Posted on Mar 04, 2008
Need to reduce the size of programs displaying
Do you have a small handgun? Fire away and you will no longer see oversized display items.
Mar 18, 2016 | Televison & Video
What is the sizes on new & worn rings on Bajaj RE205 Piston
the size of the ring will be determined by the bore size
so if it is a 3"(75mm) bore the ring will be that size if placed in the bore separate to the piston and pushed square and to the bottom of the bore the ring gap will denote if standard , worn or oversize to standard
new rings in new bores will have a ring gap of around .010"
worn rings will have a larger gap up to .040" and will have sharp edges where the ring lands wear the rings
over size rings in standard bore probably won't even fit in the bore to start with
ring sets are bought in standard size , .010" over size,.020" oversize,.030" oversize,.040" oversize with the oversize equalling the final hone of a machine bore
so if the machine shop bores the cylinder out to .020" oversize then you need .020" oversize rings to maintain the correct ring gap
from experience I have found that if I follow that rule , on measuring the ring gap at the bottom of the bore the ring gap is about .015" or half worn out
I counter this by getting the next size ring .030" and filing the ends of the rings at the gap to obtain the .010" gap This has produced better longer lasting repairs
Jul 27, 2015 | Bajaj Motorcycles
How can i tell how old my remington model 1100 is
Hi tommyw57
You will never find a recoil pad made just for the 1100 unless you buy one from a gun show that came off of an 1100.
Go to Walmart and pickup the recoil pad of your choice, install it on your 1100 and draw the outline of the stock on the oversized recoil pad.
Remove the pad from the gun and on a grinder, reduce the size of the recoil pad down to the size that fits the stock of the 1100 that you drew on the oversized recoil pad.
Please take time to rate me
Bud
Oct 31, 2012 | Garden
While playing a game the screen suddenly reverted back to the home page but reduced in size and with no cursor. I have tried turning it off and even removing the battery but just get the same reduced size...
In most cases this problem comes up by Antivirus program. It checkes running files. To identify the problem try disale antivirus program temporary, start your game and see what happens.
Mar 27, 2011 | Dell Vostro 3500 Laptop
I recently installed a 32 inch LCD TV. The picture appears to be oversized and I do not know how to reduce the heigth and width.
You should download the user manual so you will know how to make the adjustment;
http://www.retrevo.com/support/Insignia-IS-LCDTV32-TVs-manual/id/8223ag521/t/2/
You need to look for 'ASPECT', 'P.SIZE', 'ZOOM' I.E. on the remote control.
Feb 18, 2011 | Insignia IS-LCDTV32 32 in. Television
What is the difference between standard size main bearing and oversize main bearing. Which is best for the 5.4L V8 engine
thats a good un? ok standard bearings are a standard size,,,over size bearings are smaller in the center to make up for the metal that has been removed from when the bearing was re-fased
ie: ground down to smooth it off so its flat again,,,,,now you can fit oversized bearings on a standerd bearing becouse they would be far to tight and would lock the bearing up,,,,so you need to re-grind the bearing serfice or fit standerd bearings back in,,,only if the shaft is a good one?
i hope this has help you out
Nov 28, 2010 | 1997 Ford Expedition
Mouse changing my page size
Your Ctrl Button is continously being pressed that is why this is happening. You can restore the page by pressing both Ctrl + Upper Arrow in case to increase the size and for reducing the size press CTRL+Down Arrow
Apr 05, 2010 | Samsung NC20-21GBK Notebook
Cursor and keyboard movment responds very slowly
Does the slow movement of cursor and keyboard seen only on excel? Given that your excel is not corrupted, it just could be the file size of the worksheet you are working is too big. But if the slowness is present even on small excel file, you may consider re-installing your excel.
But if the slowness is present even on other application, then the problem could be on your pc itself.
Oct 26, 2009 | Microsoft Excel for PC
Eratic movement of cursor using touch pad
Sounds like you have a touchpad malfunction. If its an older laptop, I would recommend replacing it. Not worth the hassle of trying to install a new touchpad...
May 12, 2009 | Dell F3534 Touchpad
Oversized cursor while on the internet
  1. Unistall the touch pad driver from device manager.
  2. Restart your computer.
  3. then Click Here to Download the Drivers
  4. Install the Drivers and Restart the computer.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 30, 2009 | Dell Latitude D620 Notebook
Computers & Internet Logo
42 people viewed this question
Alun Cox
David Payne
David Payne
