Question about Acer AL1916W 19" LCD Monitor
Acer 1916w dissassembly
Hi all, I am having a problem with an acer 1916w monitor where there is a clicking noise coming from within it, i have pinpointed where the noise is coming from (top left corner with lcd facing me) however there are no screws on the case of the monitor so i cant get to it to fix it!
Please help
Thanks
Eventually I found a workaraound.
Unlike normal mode, When in Graphics mode, the monitor does not start buzzing.
A point I forgot to mention is that hitting the monitor makes the noicse go away, but after a few minutes it slowly creeps back!
Posted on Apr 02, 2008
    Genius:
  • 2,785 Answers
Dear alanwilson04
if your monitor is under waranty then it is better to give to the shop from you have purchased.
if not then you call a qualified person to solve the problem because working inside the monitor is dangerous
How do i set the monitor so the text and icons appear clean and crisp?
go to acer website and download driver for monitor or graphics monitor. Make sure you download AL 1916W and NOT AL1916. Make sure after, you set your resolution to 1440 x 900. That should do the trick.
Feb 03, 2011 | Acer AL1916W 19" LCD Monitor
I have the acer AL 1916w monitor behind the monitor there are four holes available . i want to mount this monitor on the wall . so pls help how will i mount on wall by using this hole or any possibilities...
They are Metric screw M4 or M5 from HD or LOWE's,
When you buy a wall mounting kit, it should come with the monting screw, do some research to what kind of mounting kit you are going ti buy that will have the mounting pattern that fit your monitor or if it has variable pattern that will accomodate your monitor.
User manula and support; http://support.acer-euro.com/drivers/monitor/al1916w.html
Watch out for caps going bad in your monitor also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 20, 2010 | Acer AL1916W 19" LCD Monitor
Acer 1916W flickers which started 2 days ago. Can this be corrected?
Borrow replacement monitor and if good, not usually untill a part is replaced.
If the same, then fault is in the PC.
May 10, 2010 | Acer AL1916W 19" LCD Monitor
Acer 1916W No image on screen any more.
As you can see at photos I post on photobucket.com, you will see mot monitors are bad due to bad caps. http://s807.photobucket.com/home/budm/allalbums
You should replace them with LOW ESR 105C caps, I use PANASONIC FM or FC series from DIGIKEY, otherwise they will not last.
Feb 06, 2010 | Acer AL1916W 19" LCD Monitor
ACER Al 1916W Asd service manual
dac-19m005 power light comes on then goes off
Jan 08, 2010 | Acer Computers & Internet
Acer 1916w flickering
Its either going to be a problem with puffy capacitors on the main board or the lcd is going bad on it cause the backlight can't stay on.
The cost of fixing the monitor may be more then what a new one is worth but you wouldn't know unless you bring it to a repair shop and have them look at it.
Try another known working monitor to see if you get the same symptoms, if they go away then you know the original monitor is bad. if you get the same symptoms then the video card is bad.
Jun 26, 2009 | Acer AL1916W 19" LCD Monitor
How do I remove the back from my acer al 1916W
face down the monitor over a soft surface to avoid scratches .Remove all screws that you can see.There are more screws that mount the leg to the monitor .Those are hidden you can not see.Covered by a little plastic cover shell.After you remove all the screws ,now you need to remove the back cover from the monitor .using a flat screw driver or another slim tool begin from one side .stick the screw driver into join line between the front and back cover and twist it gently.this is hard part of the operation.You got to be careful .try to loose one side first then other sides ll be easier.
Apr 06, 2009 | Acer AL1916W 19" LCD Monitor
Repairing the MB for the (Acer) AL1916 monitor
http://www.eletromaniacos.com/Downloads/Monitores/Acer/acer-AL1916v.pdf
Apr 24, 2008 | Acer AL1916W 19" LCD Monitor
Monitor resolution conflict
Install the Drivers for your New Monitor and then try increasing your resolution. If fails to solve, contact your Monitor Vendor (Seller).
Sahaja Yoga is FREE OF CHARGE and is the MAHAA YOGA.
Apr 23, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
302 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
