Question about Refrigerators
Hotpoint RLA54 fridge
When I came back from holiday everything in my fridge was frozen and many items exploded. I defrosted it and it seemed ok - however, now it is iced up down the rear wall, but doesn't seem to keep the contents cold enough. When I first bought it I had to have an engineer out to replace the gas ( which was leaking ). Could this be the same problem?
  • mmcmullen Apr 30, 2009
    my fridge is barely 2 years old and is freezing everything.
  • 236 Answers
Under charge of refrigerant is one of the ice build up in the unit, but try the defrosting method and after all ice are gone operate the unit and check vents if air is present. If no is air present inside the unit may be the blower motor inside has a defect. Its either stock up, burned, or worn out bearing
Posted on Mar 04, 2008
Hotpoint mistral fridge freezer flashing EE. I don't know what it means. Both fridge and freezer still seem to be working.Do you know what needs to be done?
It's probably timed out on defrost, take everything out (borrow a neighbours or friends freezer and transfer food) switch off, do a thorough manual defrost and check all pipes etc are clean and clear, (and if you are able clean and vacuum around the back while it's off to get rid of all the dust on cooling coils)
it'll prob be ok after that.
May 08, 2014 | Refrigerators
Hello - came back from holiday and my maytag gz2626gekb had defrosted and all food was lost, we thought that one of us had left the door open by mistake so switched it off at the mains then back on and...
If the entire freezer section had warmed up i would be looking at either the condenser fan motor (located behind fridge in compressor area) or the relay and overload assembly (attached to the compressor) as your most likely suspects.
Usually if the relay and overload fail the compressor simply will not run or you will hear an audible buzz and click sound from the component.
The condenser fan motor should be running whenever the refrigerator is on. If the fan is stalling it will cause the compressor to overheat and shut off.
Now if some of the freezer items were still frozen, you may have a defrost issue causing a restriction in air flow within your unit. Your most likely culprit for this would be the defrost control board located in the refrigerator compartment top right corner above your control housing. Part number 61005988.
Jun 13, 2010 | Maytag ZigZagW / B Side by Side...
My fridge is frozen at the back but seems too warm. its a HOTPOINT ICED DIMOND 8326. i don't know what to do.my food and milk isn't cold. its a rented property and the fridge freezer seems very old.
Let this unit completely defrost and thaw(sevral hours) which might bring it back with little or no additional repairs.These units will lock up on excessive ice and will not circulate...good luck
Jul 10, 2009 | Refrigerators
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Freezer not freezing solid. Pulled off back
Your not going into defrost, the fridge cycles into defrost every 8-10hrs for approx 20mins....problem could be multile items, the defrost time, defrost thermostat, or the defrost heater, will need a meter to ohm heater and thermostat...thermostat will be a closed circuit when it gets below 22degrees. ohm the heater out...if both check ok, will be a timer issue. Can do a simpler check....in the fridge section near controls there is a smal hole with a gear on the inside....that is your defrost timer. take a falt tip screwdriver and turn that gear until it clicks, this will put the fridge into defrost...if everything on the heater side is ok you will hear a sizzle from the ice melting
Jun 09, 2009 | Amana ABB1921DE Bottom Freezer...
Freezer and fridge are not cooling but we hear the sound of the refrigerator
your defrost heater or timer is not working . rotate you defrost timer until it clicks and check if its is defrosting if it is let it defrost for about 10 mins and turn the timer some more to take it out of defrost. replace timer
Jun 02, 2009 | Hotpoint HSS25GFP Side by Side...
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Hotpoint FFA60 frost free fridge freezer approx 4 years old. Fridge seems fine but freezer is only just about keeping stuff frozen and is not cold enough to freeze fresh stuff properly. There is a small...
before you scrap it clean the coils under the machine and make sure the airflow is not obstructed in any way then...
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Refrigerators
Fridge problem
you have a defrostion issue reed to remove the back panel in the freezer behind this panel is the evaperator coil needs to be melted down because it is full of ice and frost, ahair drier will work well,put several towells down under the bottom of the evaperator to catch water runoff, after defrosting the coil inspect the defrost heater or heaters some of these can have one or two heaters the heaters are located behind metal gaurds in the evaperator if either of the heaters are bad (both)need to be replaced, if they show good then bad defrost timer or bad defrost termination thermastat wiring diagram behind frount bottom grill
Apr 12, 2008 | Refrigerators
Refrigerators Logo
235 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
