Question about Hitachi CP-X345 Multimedia Projector
No input detected on projector
I have a hitachi pjtx-100 ceiling mounted projector that worked great when connected the following way: DVD Player>Component video cables>reciever>component video cables>projector.
I recently remodeled my house, and opted to run an hdmi cable instead of component video cables. Then I discovered that my projector does not have an HDMI input! -But it does have a DVI input. I thought the problem would be solved by buying a HDMI-DVI adapter. -No luck. The current configuration is: DVD>Component video cable>reciever>hdmi cable>hdmito DVI adapter>projector.
Maybe related- I bought a new Sony Reciever (STR DG 510) to take advantage of the HDMI output. Whenever I select "DVD" the message "unlock" appears on the display. There is now reference whatsoever to this message in any manual, so I can't get rid of it. Is the unit "locked, thus inhibiting the signal?
I'm pretty technically adept, and have gone through all of the motions of changing the input signal on the projector.
Also, the dvd player is about 5-6 years old...might the signal not make the transition from component video cable to hdmi? Thanks for your help!
Dave
Hitachi cpx345.... when plates were put into the walls and wires were soldered to the plate so no one could pull the cords from the wall, there is now no sound. what could be the problem? four also say "no input is detected on RGBI. help
  • dunno7 Oct 23, 2008
    My Acer Aspire 3630 Laptop cannot be detected by my Hitachi CP-X345 Multimedia Projector. It works without incident with a Dell Vostro 1500; just plug and play.
  • patmchere Feb 01, 2009
    We have multiples of this projector (Hitachi CP-X345) and using the same laptop, same cable, one finds the signal on both RGB inputs AND composite in, but the other finds NO signal at all on RGB and displays image in black and white ONLY on composite input.
2 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Posted on Dec 04, 2007
PJ-TX300 suddenly not detecting HDMI input
I think that its a port issue, if all the other ports are working but hdmi is not then one of the pin on the circuit board may have come loose. I have the same issue. Could try to solder it back on or use a glue gun. let me know if this helps?
Sep 21, 2014 | Hitachi PJ-TX300 LCD Projector
Video input not recognized
Will it work if you change the input to manual and select the correct imput source?
Mar 18, 2008 | Hitachi CP-X275 Multimedia Projector
I changed my desktop background and now my projector will not display
I would start by cycling this through the f4 option again first. Next I would connect the projector to the computer and then booting up the computer. Next I would disconnect the projector...turn it off, connect the projector again and then power up the projector. Try every combination of sequencing to get the computer and projector to talk to each other. It would not be a bad idea to change out the cable and try a new one as well. If it is a ceiling mounted projector then connect straight to the projector and try that.
Jan 07, 2013 | Hitachi Office Equipment & Supplies
Hitachi cp-x300 will not go into advanced mode
I don't know that model but normally mirrored (ceiling) settings are in the basic menu. Some of the hitachi models won't go to Advanced mode or some of the image settings unless there is a signal that they are adjusting as you end up with settings for the RGB input and separate settings for composite (video via phono)
Dec 11, 2012 | Hitachi CP-X300 LCD Projector
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
Projector comes on, everything seems to work, wont recognize any inputs when they are plugged in, says that there is " no inputed detected"
There are several input that you will have to select. RGB for input from computers. There are also video imput selection if you plug it into a DVD player.
Aug 10, 2010 | Hitachi ED-S3170A LCD Projector 1700 ANSI...
What size are the mounting screws?
The brass mounting holes on the bottom of Hitachi data projectors require a 4mm bolt.
Typicall 4mm x 10 is the shortest bolt I will use if when installing a projector on a ceiling mount, and 4mm x 20 will be the longest. I also recommend picking up 3 washers and spacers of varying sizes if you want to insure the projector is mounted level without warping whatever it is you are attaching it to.
BMS makes great locking mounts that come with all the mounting hardware you'd need to attach a projector to it.
Jan 03, 2010 | Hitachi CP-S240 Multimedia Projector
Hitachi XGA cp-x275
Yes, this unit is made for either or solution. If you look at the under side, you will see three screw holes, these are for your mount kit which you can get form http://www.mountsandmore.com/Projector-Ceiling-Mounts-C13810.html?refid=G6435.%22projector+ceiling+mount%22&gclid=CIyfl7G_2pgCFQEoGgodXmajdw
There are other sites as well.
Hope this is not too late.
Oct 02, 2008 | Hitachi CP-X275 Multimedia Projector
Dec 04, 2007 | Hitachi PJTX100 Multimedia Projector
Hitachi CP-X345 Multimedia Projector Logo
1,193 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
