Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
I HAVE A MAYTAG 12568AEW WITH FLASHING LIGHTS ON KEY PAD AND ICE DOOR FLAPPER RUNS CONTIUOUSLY. WHAT PART NUMBER NEEDS REPLACEMENT?
PLEASE LET ME KNOW WHAT PART NUMBER TO GET ... I HAVE ONLY HAD IT FOR A LITTLE OVER A YEAR.
  • 2 more comments
  • JIMMYJOSH Mar 04, 2008
    THE LIGHTS ARE FLASHING ON THE TOUCH KEYPAD AND NONE OF THE KEYPAD CONTROLS ARE WORKING AND THERE IS NO ICE WATER OR ICE DISPENSING EITHER. I UNPLUGGED IT AND NOTHING RESET...STILL DOING THE SAME.
    more than likely i would be doing the work.
    THANKS, I WILL NEED TO GO HOME TO OFFER YOU THAT INFO. TALK TO YOU LATER.
  • JIMMYJOSH Mar 05, 2008
    OK HERE IS THE PROBLEM..THERE IS A HEATER GRID LOCATED INSIDE THE SMALL FLAPPER ON THE UPPER DOOR THAT KEEPS MOISTURE FROM BUILDING UP WHICH HAS AN INTERNAL SHORT AND IS DRAWING TOO MUCH AMPERAGE CAUSING THE TOUCHPAD CONTROLS TO FLASH ERRATICALLY. I WOULD LIKE TO KNOW WHAT PART NUMBER THAT IS AND HOW DIFFICULT IT IS TO CHANGE?
    Genius:
  • 3,587 Answers
Flashing lights on what? the control panel?
Posted on Mar 04, 2008
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Mar 04, 2008
    those lights sometimes flash when theres' been a power interruption, or some other glitch..try unplugging it for a few minutes to allow the panel to reset.
  • Patrick Michaels
    sounds like the panel electronics are fried. Are you inclined to do the parts swap out, or is this unit still under warranty?
  • Patrick Michaels
    ok..so let's find the service manual and parts availability. Can you supply serial or part number from that unit(most likely on back panel label, or perhaps inside door).
  • Patrick Michaels
    Patrick Michaels Mar 06, 2008
    ahh..well..not hard to find or replace. you pretty handy with tools? And know how to document it on way out, so you can find your way in the same way?
Can the flapper for ice be replaced?
Refrigerator model number? ice chute door replacement
26177815-rm0wrikgpdq1hfoxb3io2p34-3-0.jpg need your model number for the correct part Dispenser Door 8201756
APPLIANCE 911
Apr 27, 2016 | Refrigerators
Ice maker stopped making ice. Red light is flashing. Temperature is below freezing. We've already replaced icemaker and the refrigerator is not even 6 years old.
Ok open your freezer door and observe the flashing red light now push the flapper inwards keeping your finger and hand out of the way of the infa-red sensors you should observe the light it should not flash but glow steady if it does not a fairly simple attempt would be remove the 3 screws on that assembly pulling it away from its location and unplug the harness, now go to the other side and remove those screws and unplug the harness reassemble both sensors and screw back into place push the flapper back in is the red light steady? No then you will need a infa-reds sensor kit I believe they are now well over 100.00. I do hope clearing the pcb on the sensor by unplugging the harness works but if not you now know how to replace the infa-red sensor.........And if the light is working steady and no ice is in the imkr then fill with water and off you go....
May 14, 2011 | KitchenAid Superba Architect KSCS25INSS...
My Maytag MF12568AES Refrierator control panel flashes on and off and the door flapper to te ice maker opens and closes uncontrolably. Whats up?
this is a very common issue the control board on the back of the unit is bad, you will need to replace it to fix this issue, let me know if you need more help,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
The entire fountain assembly needs to be replaced. The circuit boards are fried. Can this be replaced? Maytag Model MSD2756AEW The bracket holding it in place also should be replaced. Currently water is...
Part number 12001760 fountain kit(includes solenoid, flapper door &hinge pin $50,part number 61003425 control board $95,part number 61003407 fountain bracket $25.
 Depends on how much you like the fridge but thats a lot to spend on an ice dispenser. and thats assuming you do it yourself otherwise add at least another $100
Sep 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore side by side icemaker
Your product is an IDI (In Door Ice the bucket is in the door) or a Non-IDI? By the way, you mention the Ice maker. The thing is that if the ice maker is not runnning then you don't have ice to dispense and obviously the fact that the motor is working or not is irrelevant. So that's why I suppose that the problem is not the ice maker but the trajectory of the cubes from the bucket to outside of the door.
In the Non-IDI sometimes it happens that the safes in the bucket jump the locks were the bucket resides so the auger motor (the one that move the shaft so you get the Ice) is still running but you can't get ice because the bucket is not in the right position. Just try to relocate the bucket.
You can see if the motor is moving the shaft pressing the light switch that is at the top of the freezer. Then dispense, when you press the switch the main board thinks that the door is closed so you can dispense and see if the motor is moving the shaft.
Other failure mode is the flapper door, it depends if the dispenser works with full electronics or if it's an electromechanical dispenser. Full electronics dispenser use a stepper motor to move the flapper door so the failure is that when you press the pad and the flapper door is closing, if you press it again then it get stucked, the motor dispense but the flapper door is closed. With electromechanical dispenser, maybe is the dashpot mechanism.
If any of these solutions couldn't fix your problem please tell me. I think that I can solve this particular problem.
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker not working in frig
Does the flapper open?
Look from underneath, hit the dispencer lever w/o a cup there blocking your view, does the flapper open up? If not, you may have the same problem as we do.
The problem seems to be a failing linear actuator.
I'm unable to locate a replacement part, hopefully someone can help us.
Linear Actuator info:
Thermotion
115 volt
Aug 27, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerator not working properly
dispenser board needs to be replaced. There was a recall on certain Ice 2O units. Call Maytag and see if your unit qualifies.You will need model and serial number.
Jul 23, 2008 | Maytag MFI2568AE Side by Side French Door...
I have an ICE2O frnch botton freezer. The ice flapper continues running, with multiple flashing lights, and the water and ice will not dispense
you have a bad HV board in the back easy to replace..
just let me know
you can unplug the despenser at the top of the door until you get a new board
Apr 05, 2008 | Refrigerators
Ice dispenser
make sure that the flap is sitting in properly. if it is and problem still happens then i'd say that its a design fault
Nov 10, 2007 | Maytag MSD2756GES Side by Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
377 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
