Question about Protron PLTV-37 37 in. LCD Television
Changing channels the up & down doesn't work to change channels I have to punch it in?
  • 40 Answers
Mamarabbit-It sounds like you have to autoprogram your tv channels,go into the menu and try to find setup or autoprog.Sometimes if your tv is unplugged for awhile,the plugged in it will automatically start autoprog.Try this out let me know how you make out. cooltek Mar.04/08
Posted on Mar 04, 2008
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
Aveis LT15AP3
AVEIS LT15AP3; WHEN CHANGING THE CHANNEL BY LAST CHANNEL OR BY PUTTING IN ACTUAL CHANNEL , IT DOES NOT CHANGE TO CHANNEL I PUNCHED IN BUT TO CABLE CHANNEL 3. IF I TURN TV OFF AND HAVE THE CHANNEL I WANT ON, IT COMES ON THAT CHANNEL. THEN IF I CHANGE CHANNEL IT GOES BACK TO CHANNEL 3. HELP????
Apr 14, 2010 | Televison & Video
Will not change channels, but volume works.
try numeric keypad, if unsuccessful then try reloading TV code in remote
Mar 19, 2010 | Philips Magnavox Learning Universal Remote
I have an shd-3010 with the remote and the channel button doesn't work nor do the buttons to change the station on the remote. Yet the power button works as does the volume buttons
Here is the solution. I have had this problem for 2 or 3 YEARS... (I finally gave up and just changed the channel manually).
The solution is exceedingly simple. You'll want to punch yourself (or at least, I did... :-P )
Press Menu. Press Menu. Press Menu (3 times total)
THEN, scroll down to "Channel Fix"
It will say either "3" or "4." What this does is it makes it so that your HDTV is always on channel 3 (or 4) when you turn on the device... AND it apparently disables the channel functions of the remote control, for some inexplicable reason.
All you have to do is change this setting from "3" or "4" to --> "OFF"
You will now have full channel and button control.
Enjoy! <(^_^<)(^'.'^)(>^_^)>
Jul 17, 2009 | Gateway SHD-3010 30 in. HD-Ready LCD...
CHANGE CHANNELS WITH THE CONTROL
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Sony WEGA 42" LCD Rear Projection TV It won't change channels up or down with the remote or the buttons on the television.  It will change channels with the number pad on the remote but not the channel...
Hi, it sounds like your saying that punching in 08, 09 etc. works but channel up button won`t switch from 08 to 09 correct??? If so you need to go into your tv`s menu and "autoprogram" your channels into memory, video-tek
Jan 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Changing channels
Put the channels in memory by selecting CATV and then auto-program in set-up menu...................................T.
Dec 15, 2007 | Proscan PS27108 TV
Protron PLTV-37 37 in. LCD Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
