Question about Uniden BC72XLT Handheld Scanner
Unkown functions Theres a couple of things Ive found with this scanner that the owners manual does not explain: 1) While in the close call mode when the "hold" button is pressed the word 'hold' appears in the bottom left of the display with the word Lo, Hi, Air,Or uhf above it I can cycle through which one it is by pressing the "hold" button over again. I cant figure out what this does when its displayed 2) in the search mode sometimes beside the frequency number to the right a small 25, 50, 0r 75, will appear. I cant figure out what this means Any help would rock, ThX
Learn to read english
Posted on Jun 14, 2008
Lo Hi Air UHF refer to separate bands to be monitored.
25 50 75 are the KHZ steps that can be set for searching.
Using these functions can limit what is found either during close call or during search. By switching to 25 50 or 75 in will search in those size jumps. IE in 25 155.000 155.025 155.050 155.075 etc.
Posted on May 02, 2008
How to tell what the buttons do?
The HOLD key lets you freeze the scanner on an active channel. For instance, if the scanner stops on channel 3, and there's a lot of action there. you can press HOLD to lock the scanner on that channel until you press the SCAN key. Repeatedly pressing the HOLD key will manually advance the selected channel.
SCAN releases a HOLD asnd will also take the unit out of PROGRAM or SEARCH modes and start it scanning the frequencies that you've programmed.
FUNCTION selects the secondary (lower) function of a key. For example, pressing FUNCTION and then the E (ENTER) key will switch the scanner to Pgm (Programming) mode - which lets you enter and store frequencies into the unit's memory so that you can scan them later.
All keyboard functions are explained in detail in the scanner operating manual, which you can download/print here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, along with a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Apr 11, 2010 | Uniden Nascar BC-92T Scanner
2004 or 05 Jeep Wrangler dtc P2096 (Post catalyst fuel trim bank 1 to lean). It set the mil lamp and then reset it self. Pulled the code with a scanner and found 1 of 2 to be P2096 and 2of 2 to be P2096...
Here is more information about P2096
P2096-DOWN STREAM FUEL TRIM LEAN BANK 1
WHEN MONITORED
With the engine running in closed loop mode, the ambient/battery temperature above (-7°C) 20°F , altitude below 8500 ft and fuel level greater than 15%.
SET CONDITION
If the PCM multiplies short term compensation by long term adaptive and a certain percentage is exceeded for two trips, a freeze frame is stored, the MIL illuminates and a trouble code is stored. Two Trip Fault. Three good trips to turn off the MIL.
Here are some possible casuses:
Exhaust leak
Engine mechanical problem
02 sensor
02 signal circut
02 return circut
Fuel contamination
Good luck and hope this helps.
Jun 21, 2009 | 2006 Jeep Wrangler
I found this CamCorder in the woods out hunting. It is a SONY model number CCD-FX710 When I turn the cam on the tape plays all functions but the screen is like a ant race on the playback mode and when...
Could be a bad tape motor. May explain why it was in the woods.
Here is a link to the owners manual:
http://www.docs.sony.com/release/CCDFX710.PDF
Feb 18, 2009 | Sony Video Cameras
Closed caption
look in the functions on the remote theres a tool section or set up guide that will come up look in owners manual
Sep 19, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Pro-94 does not function properly
your site sucks your supposed have awnsers theres 3 other people with my same prob and you mean to tell me theres not one geek that knows the awnser
Jun 02, 2008 | Radio Shack Pro-94 Scanner
UNkown functions on the bc72xlt
1) the words Lo, Hi, Air, and UHF are indicating that you told your scanner to hold on a specific frequency modulation, this is normal, pay it no mind.
2) these numbers represent sub-frequencies that are encoded into the scanner's frequency ID decoder. These numbers can also sometimes identify the frequency's pre-programmed bank number.
These problems are all basic functions of your scanner, I hope this answered your questions.
Mar 04, 2008 | Uniden BC72XLT Handheld Scanner
Funnest ust virus
theres a couple of things you can try....1st restart pc to "safe mode" and try to physically remove the virus from the file its located, then if fails try use "prevx 2.0 (its a free download trial version) and see if it will remove it, if that fails try; http://vil.nai.com/vil/stinger/ its a free virus remover from McAfee, if that fails then do a system restore to a point before the virus was found, if that fails format hard drive and reinstall windows.
Nov 27, 2007 | Computers & Internet
Graphing inequalities
While the graph function menu is on the display press the F3 button to display the graph you want to do. Then press the function key that corresponds to the graph that you want. If you have the manual it explains it on page 117. Kind of hard to explain it here when you can't type the buttons. LOL
Jun 07, 2007 | Casio FX-9750GPlus Calculator
Uniden BC72XLT Handheld Scanner Logo
109 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
