Back to:
Tags:
Uniden BC72XLT Handheld Scanner
UNkown functions on the bc72xlt
posted by Murch on Mar 04, 2008
Theres a couple of things Ive come across with this scanner that the owners manual does not explain:
1) In the close call mode if the "hold" button is pressed on the bottom left the word 'hold' will appear with either the word Lo, Hi, Air, Or uhf above it, I can't figure out what this is for.
2) while in search mode SOmetimes to the right of the frequency number a smaller number will appear, usually a 25, 50, or 75. Cant figure out what this means
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 04, 2008
FixYa! (100)
Gavin93
Rank:Guru Guru
Rating: 86%, 18 votes
1) the words Lo, Hi, Air, and UHF are indicating that you told your scanner to hold on a specific frequency modulation, this is normal, pay it no mind.
2) these numbers represent sub-frequencies that are encoded into the scanner's frequency ID decoder. These numbers can also sometimes identify the frequency's pre-programmed bank number.
These problems are all basic functions of your scanner, I hope this answered your questions.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on UNkown functions on the bc72xlt:
I don't want to Accept this solution
Solution #2
posted on Aug 20, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The other answer is wrong on #2.
The numbers 25, 50 and 75 which appear to the right of the frequency are the stepping. Channel bank numbers appear to the left and are 00-99.
Thank You!
Can you Help with these Radio Scanners problems?
Radio Scanners
how do i re program if im locked out? please help!
Radio Scanners
I have a fr err on the display of my scanner it won't let...
can you please help me with obtaining the frequency codes...
fgegrehtttttttttttttt
hi i purchased this radio scanner but it didnt come with a...
Loading problems.
Repair Service
Find Radio Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
