Question about Canon PIXMA MP780 All-In-One InkJet Printer
Color drop out
I'm having a problem in that certain colors are dropping out when printing, the irony being that they are not always the same one. For example, magenta wasn't printing and now after countless deep cleans, cleaning the heads and replacing cartridges that are drying out in the process, the cyan won't print.
When I print out the check pattern the color bars all look fine, including cyan but it has dropped out of the letters on the left, so one would suppose the ink can get through but for some reason won't.
Any ideas?
  • hookka Mar 07, 2008
    In my case the magenta refuses to print on the test sheets while doing the print check. I have gone thru numeraous clening sessions. Everything I print comes out with a green hue. I can not print the reds.
    Any solution will help
    Thanks
  • Anonymous Mar 08, 2008
    Actually looking at the color bar printouts on the test pattern, I see
    that though the cyan is printing it is printing a llot dimmer than it
    should be, which is presumably what is giving everything its brown
    tinge.
    Sergeant:
  • 197 Answers
Sounds like the print head itself has clogged or some inks have become harder... can happen over time especially as you dont know how long inks have been on shelf before you bought them... some brands are better than others for that...
Posted on May 04, 2017
2 Suggested Answers
  • 12 Answers
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
Apple deskjet 842c printing
re-install the driver for 842c
Mar 25, 2017 | Computers & Internet
I just installed a new color cartridge for an HP 5650 Deskjet printer but it only prints in black. I'm printing from a MacBook, OS 10.6.6
Hi, Try printing whatever you were wanting to print but click the drop down arrow right next to the printer selection tab. Then you should see a drop down menu about halfway down the menu, click it and select print settings. You should see another drop down menu called color, just click it and change it from grayscale to color.
Hope this helps, Justin
Feb 13, 2011 | Apple MB985LLA 15.4" Macbook Pro Notebook...
Hello. How do you clean the cartridge as it is a little dried up for printer HP PSC 1210 all in one printer?
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
The best solution for you is to buy some isopropyl alcohol from chemist, which is a great solvent for dried ink, and drop 8-10 drops into the ink nozzle, put it back in and try running a few prints then repeat the process. If it doesn't help, you will be better off buying new ink cartridges.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
How can I change the setting from grayscale so that it will now print in color?
Go to print as per normal under the drop down box beneath the number of pages. In firefox the drop down box would be firefox and then in the drop down menu select Paper Type/Quality then change the color from grayscale to whatever color options come up. Hope this helps.
Dec 13, 2010 | Apple MB985LLA 15.4" Macbook Pro Notebook...
The color is printing no colors, i perform the test and it shows it is ok, but when i try to print the printing comes out in a light oinkish, redish color.
Click start > open control panel > open printers folder.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click on Next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Verify the printer name and set the printer as default then click next.
Select replace current drivers
Do not select print a test page option.
Click on Finish.
Aug 16, 2010 | HP Photosmart C3180 All-In-One InkJet...
I have a Deskjet 932c and it won't print in color black and white is fine though. I just bought a new cartridge and is still doesn't print color. Is it shot??
I use a small diameter silicone tube tocarefully "prime" stubborn new carts by sucking a drop of ink out ofthe tiny print holes in the printhead part of the cart. Ink can dry at the headand since these carts work by electrical excitation, there needs to be liquidof each color at the holes. Slap a drop of water with your finger on the holesto start easy hesitant ones. Do not get the contacts wet.
May 13, 2010 | HP DeskJet 932c InkJet Printer
My Kodak printer ESP3 is not printing. It keeps flashing over the 3 color tear drops (red,green,purple). Ive powered it on and off several of times as well as checking the cords.
This 3 color drop flashed when the color ink cartridge needs to be replaced.
Try to use a new color ink cartridge > If no go, call Kodak they will replace the color ink > If no go > Call Kodak and this time they will replace the printer
Jan 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Is there a setting to print in B/W only?
Yes
When printing press file,then print, from there select printing preferences go over the pages and look for black and white setting or grayscale setting.
it will print in black and white only.
May 29, 2009 | Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
62 people viewed this question
old marine
old marine
