Question about Apple MacBook Air
Macbook air Crashed, bricked or just a power problem?
I was doing some work on my computer and then I left it with the power cord on and then after a while I found my macbook with no power. I tried unpluggin and plugging it or reset it by pressing the power button for 10 sec.... nothing seems to work.
any ideas?
  • suekg6 Jun 24, 2008
    Just bough Apple Air and it was working all day then all of a sudden it wont start there is absolutely no action at all. Have tried unplugging but to no avail.
That is odd. I have had a fantastic experience with my MBA so far. The good news for you is that, since you have a MBA, you are probably within the 90 window in which you can seek unlimited complimentary support from Apple.
If you are close to a retail store, take it to the Genius Bar. Otherwise, check out this link for info on phone support:
http://www.apple.com/support/complimentary/
Posted on Mar 26, 2008
I need an ac adapter for ayear 2000 apple powerbook
Is it the round, puck-shaped power supply? These are prone to failure; cords usually go bad. The brick-shaped power supply develops issues at the plug where it is inserted into the computer. In any event, your best source is Ebay. Get the computer year and model number and do a search. Sometimes you'll find old computer stuff on Craigslist. Buy two if you can find them and keep one as a spare. Better yet, since you are using a legacy computer with an old operating system, transfer your data to a portable hard drive and update to a more modern Macbook. 2007 models go for $100 on Ebay and they work with modern operating systems, such as OS 10.6.8 and the latest browsers.
Sep 07, 2015 | Apple Computers & Internet
What is power brick cord?
An AC adapter, sometimes called a power brick, is a little box that takes the Alternating Current (AC) line voltage from your house receptacle and converts it into a Direct Current (DC) voltage that is used by your electonic device (computer, hard drive, etc.). This power brick sometimes has a separate power cord that is removable from the brick. This cord usually connects to your house receptacle, and sometimes it is a standard cord with standard connectors on each end.
Nov 10, 2013 | Pacific Digital (U30274) DVD±RW...
Will not load up or take charge
Try removing the AC power, removing the battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
If that doesnt work try this:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Mar 01, 2011 | Apple MacBook Air
MacBook Air 11" won't power
1. Verify AC power presence with MagSafe LED indicating on or charge state.
2. Verify battery as being partly charged, with orange/amber LED on MagSafe power connector.
3. Reset SMC
Resetting the System Management Controller (SMC) The System Management Controller (SMC) is a chip on the logic board that controls all power functions. If the computer is experiencing any power issue, such as not starting up, not displaying video, sleep issues, or fan noise issues, resetting SMC may resolve it. To reset SMC: 1. If computer is on, turn it off by choosing Shut Down from the Apple menu. 2. Connect power adapter to computer and to a working power source. 3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just once. Important: Use Shift-Control-Option keys on left side of keyboard. Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will change it to green for a few seconds, indicating that SMC was correctly reset. 4. Wait 5 seconds and press power button to start computer. Note: If bottom case is removed, you can alternately reset SMC by disconnecting both power adapter and main battery, and holding down power button for 5 seconds.
Power Adapter Issues 1. Connect AC adapter's MagSafe connector to the computer. The LED on the connector should be green or orange/amber. 2. Verify power cord or duckhead is firmly attached to AC adapter. Check that duckhead is not damaged. 3. Verify AC power source is supplying AC power. 4. Check for dirty or stuck pins on the MagSafe connectors, both on the adapter and the computer. 5. Reset SMC by pressing the (left) Shift-ControlOption(Alt) keys along with the power button once.
Jan 29, 2011 | Apple MacBook Air
It shows message as "turn on camera" while try to
Assuming your computer has a built-in iSight camera - which should be all Macs made since 2006 except for the Mac Mini and Mac Pro (not MacBOOK Pro!) - your camera
a) May not be being seen by the computer. Check Apple Menu > About This Mac > More Info > USB and see if "built-in iSight" is listed in the USB Device Tree. If it is, then it may be being used by another application that uses a webcam, like Skype, iChat, or what have you. If it IS NOT detected:
b) Try resetting your SMC:
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
  2. Unplug the computer's power cord.
  3. Wait fifteen seconds.
  4. Attach the computer's power cord.
  5. Wait five seconds, then press the power button to turn on the computer.
Dec 20, 2010 | Computers & Internet
Macbook goes to sleep and doesn't wake up unless I do a hard reboot.
I have seen this caused by having a mouse plugged into mine. I have removed the mouse and touch the touchpad and it has come up from sleep.
That very well may not be your problem.
Here is the procedure that is recommend from Apple to help with the not waking from sleep problem. I included both methods as it is not clear which macbook you have. I also included the link to the article at the bottom.
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
Here is the link to the article at the Apple support site.
http://support.apple.com/kb/HT1411
Aug 28, 2009 | Office Equipment & Supplies
My mx6128 is dead
Check and see if your power brick's light is on. The power brick is that black block of plastic on your power cord. If that light is dead then the power brick is bad. That should be your first item to check.
Apr 02, 2009 | Gateway MX6128 Notebook
My power cord no longer works
If the cord is a standard computer cord then Radio Shack, Best Buy or any computer store has a cord. You could also try removing the cord from the computer and trying that cord.
If it's not a standard cord then you will most likely have to go to the monitor manufacturer. Another possibility is that the brick may have gone bad. Again you will probably have to go to the manufacturer.
A possible fix for the brick is one of the third party bricks. These are made by I-go and Targus. Office Max and Office Depot carry these bricks. I don't know if they are compatible with your monitor, but it's worth looking into. These are usually sold as replacements for laptop bricks. Also don't forget E-Bay as a source of replacement Bricks. I had an LCD TV with a bad brick and got a replacement on E-Bay. My TV problem was very similar to what you describe.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kenneth_305861ac5ab3ccfd
Mar 31, 2009 | X2Gen MW22U Monitor
Lexmark 9575 has no power
Sounds like a bad brick. If you have a computer repair place near you take the machine to them and have them test the brick or try a new power cord. Usually a new cord will take care of the problem. Rarely the plug on the printer goes bad so hopefully it is just the cord.
Mar 24, 2009 | Lexmark X6170 All-In-One InkJet Printer
Apple MacBook Air Logo
130 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
