Question about LG Flatron L1750S 17" LCD Monitor
Monitor hit with a Headphone
I got my head phone strongly hit with the LCD monitor. A small black coloured layer was formed onside of the screen and it grows big everyday. what can I do?
  • 298 Answers
L1750S LCD Panel can be found here.
Posted on Mar 05, 2008
  • 121 Answers
You have broken the lcd it needs a new one its the liquid leaking
Posted on Mar 04, 2008
  • LG Master
  • 19,396 Answers
The black spot can stop or keep spreading, but it will never disappear or reduce in size. This is caused from a leak of liquid between layers inside the lcd panel.
Nothing to do apart changing lcd panel. Bring monitor to nearest service and check if it is worth being repaired (changing screen panel).
regards
My hp w2007 turned blue after I moved it how do I access screen display from the monitor menu
Some monitors change colour if there is damage, internally, within the signal cable. Try another cable if you have one.
Alternatively, it might be that the monitor is near an extremely strong magnetic source, such as big loudspeakers?
Mar 11, 2015 | HP W2007 LCD Monitor
Tip
Power Light blinks on then shuts down - Black Screen
I couldn't find any fix on this monitor so I had to go it alone.......
My VG500b monitor would power on then the power light would blink off. there was no display at all but I could see the LCD panel change in brightness just a small bit during the power on and then power off. I found that there was a bad capacitor on the inverter board. I replaced the 47uF 25v capacitor with a 47uF 35v capacitor. (The 25v would be okay but I always replace a failed capcitor with a higher voltage rating) This capacitor is the shorter form in order to fit under the shield. You can use a taller capaitor but you will have to lay it down, as in bend the leads down and lay it on it's side in order to fit under the sheld when you put it back together. VG500b fired right up and is going strong once again. Hope this helps someone.
on Jun 16, 2009 | ViewSonic VG500b (Black) 15" LCD Monitor
L750 block of colour on bottom half
Your lcd screen is going bad. It's either the lcd screen or the video card inside the computer. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok then your video card is ok, but your original monitor is bad. If the Borrowed monitor displays the same as your original monitor then your video card is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 08, 2012 | Toshiba Satellite L750 Notebook
LCD MONITOR DISPLAY PROBLEM
What your describing is a major video problem, poor color and it is blurr, It would be far cheaper to replace the monitor with a new one.
Mar 08, 2012 | Samsung SyncMaster Computers & Internet
I hav buyed a new acer v173 lcd monitor,and used upto 10 months till now.Lastday when i switch on my lcd,it showed the Acer logo , and suddenly the color of the screen changed,now the lcd works but i could...
Sounds like a problem with the video board of the monitor. I would contact Acer, since it less than 3 yrs old, tell them the problem that you are having get an RMA number and they will fix it for free. You only have to pay for shipping it back. Hope this helps.
Jul 29, 2010 | Acer V173 b Monitor
Screen colours are black blue & orange. No
Before i answer ung problem,i asked question first. is your monitor near to aircon? if it's near to aircon the magnet of your aircon is the cause why your monitor have defferent colours. if you're not near to aircon you can adjust the color of the monitor by adjusting the small thing at the back of the monitor. you must open the monitor case.
Nov 28, 2009 | Office Equipment & Supplies
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black screen after a couple of seconds
The monitor needs to be replaced. I had an LG LCD that did this luckily it was still under warranty. Contact the maker and have your receipt handy. Otherwise buy a new monitor. Monitors tend to be replacement only
Apr 11, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Viewsonic E71f suddenly a change in colour as if a layer formed
there must be a loose contact between tracks of base on crt or may be dry solder remove it problem may be solved
Nov 21, 2008 | ViewSonic E70 17" CRT Monitor
Two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Sep 24, 2006 | Samsung Syncmaster 730B 17" Flat Panel LCD...
LG Flatron L1750S 17" LCD Monitor Logo
141 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
