Question about Canon LV-7210 Multimedia Projector
No picture Red light flashes then goes green. On/off button is pushed, red light flashes, fan runs then unit switches off (on/off power light goes to constant red). With the lamp blown, will I be able to get a picture out of the RGB output onto a monitor (only purpose of this is to be able to fault find without buying a lamp).
When you turn it on if you haer a high chirp chip befor the light turns red
starter ok lamp has reach its life needs to be replcce
Posted on Nov 19, 2008
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Sony KDF-37H1000 37" HDTV
Installing a GE digital wall timer. Instructions say" connect Hot/live wire of main to black of timer. Connect Hot/live wire of load to red of timer. connect white of (neutral) to white of timer. green...
Review:
Black goes to Hot wire from breaker box
Red wire goes to Load (light, fan, motor)
White wire goes to Neutral
Green to bare copper ground wire
Orientation:
Your original switch had 2 wires plus bare ground.
One of these wires is Hot, the other goes to Load.
You said original wires are Red and Black
How do you find Hot wire?
-Your original switch had 2 wires.
-Remove timer from box.
-Pull original 2 wires out where you can test them
-Turn on power
-Use regular tester
-Tape tester leads to wood sticks so your hands stay away from voltage
-Power is on
-Test each original wire to bare ground wire
-When tester lights up, that is Hot wire ... this wire connects to Black wire on timer
- The other wire goes to Load so it connects to Red wire on timer
How to test for Neutral wire
Test Hot wire to your white wires - No need to untwist them.
When tester lights up, that is Neutral
White wire from timer connects to Neutral.
Green goes to ground wire.
How to reset timer
I'm not sure which timer you have. Probably GE 15086. Reset is small round button below HOUR button. Use paper clip and push-in reset until timer flashes 12 o'clock.
Sep 25, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Kds55a2000 red light flashing
The SONY Owner's Manual for the KDS55A2000 does not state what the 4 times blinking Power LED means.
However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
Power light.
I do not agree but am forced to buy a replacement lamp (not cheap) to prove that the problem is probably the fan, as the TV Technician states elsewhere in these FixYa support questions and answer
Nov 10, 2007 | Sony KDS55A2000 55" HDTV
Canon LV-7210 Multimedia Projector Logo
655 people viewed this question
old marine
old marine
