Question about Sony Playstation 3 (PS3) Console
Ps3 is a piece of sh*t
There is no video or audio on my ps3 and the fan inside quit working so i replaced the plug and it use to boot up but has not since i replaced plug on fan
  • gtex Mar 05, 2008
    Fan quit working - any solutions?
The ps3 is nothing but a piece of shit
Posted on Mar 04, 2008
I have a CECHA01 model (60 gb) PS3. Lightning recently messed a few things up which includes the PS3 (yes i was using a surge protector). Every time I start the system the fan gets really loud for 6-7...
Okay, hold the ps3's power button until it shuts off. Then hold it again until it beeps twice. When prompted, plug your controller in. Press the PS button on your controller. Now, dpad
Jul 20, 2011 | Sony Playstation 3 (PS3) Console
I have a brand new 320 GB PlayStation 3 Slim. Most everything works fine on it, however I'm having one consistent problem: I can only play games for 20 minutes or so before the video drops out and the...
If you've had this happen with two systems in a row, then it may not be the systems. First, try hooking up the PS3 directly to the TV, or another TV, and see if the issue still occurs. If it does, then something between the PS3 and the TV is causing your issue. Otherwise, call and get it replaced again, and hope the issue doesn't happen again.
Oct 04, 2010 | Video Game Consoles & Games
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Mar 01, 2010 | Integra DTR-5.1 Receiver
My internal fan quit working and i am now using fans that are around the house to keep it cool. know i was playing a game for like 3 hours straight and i went and watched a movie and it froze about 20...
Does the PS3 work again afterwards?
Do you still have control of the PS3 when the movie freezes; can you fast-forward/skip past the point it stopped.
If the movie freezes at the exact same point again, then it is a defect with the DVD, or is dirty/scratched.
if the PS3 is still working at all.. REPLACE THE FAN NOW! It should be quite simple. while one PS3's CPU may be able to handle overheating a thousand times and never break, another PS3 may overheat once and permanently destroy or weaken the CPU!
If the fan is just dirty, you should be able to open it, rebuild the fan by removing the (probably) sticker on one side and using a pin to pop off a retaining washer.. then you can push the fan blade off and clean the bearings and everything with isopropyl alcohol. put JUST one or two tiny drops of oil on the bearings/shaft and reassemble.
There may just be a hair inside. Often, fans have rubber o-rings inside -you SHOULD remove these as they will ALWAYS eventually stop the fan from working again if they've failed once before already.
If the fan is actually dead (quite rare) then you can purchase one online. Get an exact replacement, or one with the same measurements and either the same, or better, specifications (will be written on the fan, and can be searched online -important that the new fan moves as much CFM cubic-feet-per-minute of air)
Aug 31, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 is making a high pitched ringing sound the entire time it's on now...how to correct?
what model is this playstation?
and how old some older models the fan makes a lot of noise in the need to replace the fan is your bluray drive working properly? if is then inside the ps3 there is no moving parts other than the fan and the bluraydrive if you need to replace your fan I have replacement parts for the ps3
Mar 27, 2009 | Sony Playstation 3 (PS3) Console
I loose all audio on my PS3
PS3 are not made to keep powered on as they other heat.
Buy a cooling unit for it this will help, or just stick a normal house fan near it.
Hope this helps
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
Dvd broke inside ps3
try to put a blank cd into the system hopefully the piece will just come out with other cd if this dosent work contact sony 1800-345-7669
Jan 04, 2009 | Sony PS3 40GB Best Sellers Bundle Console
PS3 stopped working
the "no video" problem is quite common. you most likely have cold or even worse, bridged solder joints resulting in poor connections in your RSX/CELL processors.
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
PS3 has no audio or video
Make sure the system is off. Hold down the Power Button for 5-6 seconds until you hear the second beep. Your video settings should now be reset and you will be able to choose your connection type. It will automatically default to AV so make sure you at least have that plugged in.
Jun 05, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
