Question about Canon PIXMA MP830 All-In-One InkJet Printer
Printing document at 100% size
Where in the settings in the printer is there the option to print a document at 100% of the document
  • 1 more comment
  • lillibelle Mar 10, 2008
    thank you for your help - however i had changes the printing percentage however the printing is still small printing size on paper.
    I have restored the preset settings however the screen reads back to same magnification
  • lillibelle Mar 19, 2008
    thanks rebooted computer reinstalled software and then selected as default A4 - thanks everyone this is now fixed.
  • Anonymous Mar 14, 2014
    won't print document - change reg d size to common settings
    Master:
  • 619 Answers
Hi open the print preview it select the opening of any kind of percentage printing documents.
Posted on Mar 09, 2008
IT JUST PRINTS TO SMALL
printers only print what they receive in the down load
check the font size of the original document and adjust that if necessary
make sure that the driver for the printer is the latest version and is compatible with the computer.
May 02, 2015 | HP Officejet 5610 All-In-One InkJet...
How to change font size
The font size is determined by the document and the software, not the printer. If your printer is making the text a size different than that in the document, check your print settings to make sure that you have set the paper scale to something less than 100%.
Aug 23, 2014 | Samsung ML2165W - ML-2165W Wireless Laser...
Hp officejet 7000 won't print 6.5 x 10 paper size
Officejet 8620 printed about 400 for me in 16 months then stopped. A few weeks prior to the error msg. that the paper in the tray did not match my document settings another message said it did not recognize any paper in tray including letter size despite there being about 100 sheets. I c alled HP two different days, tried documents on a brand new computer, created a new document. Took two hours total and $20 to be told the printer did not support this paper size. I called them prior to purchase and told them my needs and was told it would accommodate the size. My local techie and I both think the sensors have gone bad in under 2 years as I had been able to print my cards with no issue about 400 times. I called Epson three different times and each tech support person says Epsons can accommodate this.
Aug 08, 2012 | HP Officejet 7000 Wide Format Printer...
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
Trouble printing
It'll be better for you to use the built-in A3 paper size, otherwise you'll not be able to print it perfectly. I you would like to do it, You can try this, after setting the documents and the documents size, give the print command, and under the printer properties, select the paper size, you'll see an option (custom) from the drop down list, select it an set the size, but you must leave a space for the printer to hold the paper. Good luck. Thanks for using FixYa.
Jun 02, 2010 | Brother MFC 6490CW InkJet Printer
I replaced my ink cartriges and I'm still have a blurr and fade on documents that I print.
  1. Open your application program.
  2. Select Print from the File menu. A Print window appears.
  3. Make sure EPSON Stylus CX9400Fax Series is selected.
  4. Click the Preferences or Properties button. (If you see a Setup, Printer, or Options button, click it. Then click Preferences or Properties on the next screen.)
    A printer properties or preferences window appears.
  5. Select the type of document you're printing for the Quality Option setting.
  6. If you want to print borderless photos, click the Borderless checkbox.
  7. Make sure you've selected the paper type and size you're using for the Type and Size settings in the Paper Options section.
  8. Click the Advanced button. The Basic settings change to the Advanced settings.
  9. Make sure the High Speed option is not selected in the Print Options section.
  10. Make sure the Black Ink Only option is not selected in the Print Options section if you're printing a color or black and white photograph.
  11. Select ICM in the Color Management section if you're trying to precisely match on-screen colors.
Jan 18, 2010 | Epson Stylus CX9400 Photo Printer
M hp psc 750 printer has started printing documents in a much smaller font to which I'm copying. How can I get it to print in the same size as the document is set in
when you choose copy option that time choose the option 100 % or you change the setting of copy by set in menu got to copy setting and set the default option.
Sep 15, 2009 | HP PSC 750 All-In-One InkJet Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
MP760 printing not at 100%
On the Printing Properties/Printing Preferences page, Page Setup tab, check and make sure that 'Normal-size printing' is selected, and that both Page Size and Printer Paper Size are set for the size paper you are using. It sounds like your settings are currently set for Scaled Printing or maybe Poster Printing.
Jun 05, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Font size problem when printing documents
Font sizes are a program thing nothing to do with the printer
 Examine your E-mail client set up in the read section[Different E-mail programs different setting ] probably under a heading
Tools/Options and look at how the font sizes are organized.
Oct 11, 2007 | HP PSC 2210 All-In-One InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
57 people viewed this question
old marine
old marine
