Question about Gateway (5500778) Internal 32x CD-ROM Drive
Cd -ROM does not recognize any disc that is inserted into it.
I have XP as my OS and I have trouble with the CD- ROM: It does not recognize and disc that is inserted into it.
    Guru:
  • 1,463 Answers
Hi
Okay first does "any disk" mean ANY disk, or any disk in the same pack of blanks ? Some cheap media has this problem.
If not, then you probably have a hardware problem.
Try checking Device Manager for flags. Report them here.
someone will know more .
If none, your optical drive may be bad.
I'm assuming "delete the drive and reboot" means uninstall the drivers Device Manager. Did they have any flags before ?
Make sure to enable "show hidden devices". You might have a non-plug & play device driver in conflict, and they are hidden.
What software are you using to burn disks ? There may be a problem with that. If there are no flags in device manager, uninstall the software (if it's Nero, Roxio or something). You can reinstall the software later.
riz.
Posted on Mar 04, 2008
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
Os install problem
firstly insert windows xp disc in cd drive
then restart your system
select first boot device cd rom
you have a option i.e press any key to boot from cd, press any key
setup will start
follow the option
select the drive in which you install the windows xp
after complete these steps
system will restart
when system restart
it takes apx. 30 minute to complete the installation
Apr 10, 2009 | Computers & Internet
CD ROM does not recognize that a disc is inserted -Dimension 2400
i think your cd rom is damaged. you can clean the cd rom lanse or you can buy a new cd rom or your cd is damaged.
Jan 28, 2009 | Dell Dimension 2400 PC Desktop
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Jan 24, 2009 | Dell DVD-rom DVD Drive
LOADING DISC
except XP os disk is not oping automatic so please after insert the disk go to my computer and doble clik the f drive it will open still its not open cd is correpted
Jul 03, 2008 | Zenith Data Systems Zenith (OP-260-74501)...
PRINTER INSTALLATION PROBLEMS
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Pioneer DVR-112D disc recognition
what i would do is install one drive as the master on ide 2, and the other as the slave on ide 1 and what OS are you using?
Sep 13, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
Gateway (5500778) Internal 32x CD-ROM Drive Logo
958 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
