Question about Panasonic DX-2000 Plain Paper Laser Fax
Error 714 on DX-2000
The scanner/fax is connected to the network and is patched in fine. But im still getting the error message. What other things can i try? I've reset the RAM, checked all cables and replaced the network cable.
    President:
  • 2,072 Answers
First off can you ping the printer?
Then make sure in your network settings you set the printer for a manual or static IP address so it is not changing on you.
Try turning off any firewalls you have on your computer or network. On a firewall, you can ping the printer but it will not sent print data. You can write the IP address through the firewall to allow printing.
Log onto your web browser and type in the IP with the firewall on and see if you can see the printer. Then shut off all firewalls and do the same thing.
Also see if the printer has an IP filter enabled, that will stop it from printing also.
Posted on Mar 04, 2008
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
What does error 716 mean on a panasonic dx 2000 internet fax?
You have a network interface problem. Fax machine cannot log onto the network.
Feb 15, 2010 | Panasonic Office Equipment & Supplies
What is Error 2200 when I try to fax something?
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off the AIO and remove the power supply from the back of the unit.
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Jun 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
Code 721 keep coming up and the machine keeps beeping. How do we fix it?
Error 721: Cannot connect to the Pop Server. (Incorrect POP Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the Network Administrator
Were you setting up email by chance, you need to make sure the email server settings are set correctly for your POP email provider. Otherwise you will get this message. If you don't use email, go into settings (Fax Parameters) and disable email features.
Apr 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Error message: cannot detect scanning device
This worked for me:
Go to http://welcome.solutions.brother.com/ , navigate to Error message for your scanner model. The patch on this page worked for me
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000082/faq000182_001.html?reg=us&c=us&lang=en&prod=mfc7220_us_as&Cat=
I notice there are several other patches as well, which may be appropriate for your specific issue. I have my mfc-7820n networked at home, at first none of my 4 computers could scan, now 3 of 4 can. I am hoping that one of the other patches will help.
Dec 02, 2007 | Office Equipment & Supplies
Errors
Hi Jean, The issue can occure only when the HP printer is not gettting enough power supply or the scanner bulb is not getting heated up properly.. You can isolate the issue by directly connecting the printer to wall jack and powerup the printer and try to make a copy so that we can check the copy function as the copy,scannig and FAX use the same scanner bulb to performe all functions.. If the copy does'nt work try to lift the scanner lid and check if the scanner bulb is lit and the scanner machinasium is moving fine or not .. lift the lid and press scan button to check the functionality. If the printer is connected to a surge protector or power strip this will some time fail to provide the required power supply to the printer so connect it to wall outlet and check with the issue.. There is also a FIRMWARE UPDATE RELEASED BY HP to fix the some of the scanner failure and receving faxes issue with HP 6110 All-in-one Here is the weblink to download and install the firmware update just click on the link to open the download page and then click on download and select save to save the patch to computer and run it to install the update make sure that the printer is connected and turn on while installing the patch The link to download: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14700-3&lc=en&cc=us&dlc=en&product=79477&os=228&lang=en Hope this will fix the issue.. If the issue is with the scanner failure message try the instruction in the below weblink: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en Wish you success Jean Regards, Barret
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Panasonic Panafax DX-2000 Super G-3
try to do a lbp fuser reset and lbp error log clear and let me know if that helps
Dec 24, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
Error message 714
hi RESET !! first clear all files from the memory cards (if there is) enter "001" and press "set" to delete all files enter "1" (page 143 ) http://service.us.panasonic.com/OPERMANPDF/DX2000AU.PDF take the battry out (page 196) unplug the device for a day and assemble it hope it works good luck
Apr 04, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
Panasonic DX-2000 Plain Paper Laser Fax Logo
107 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
