Question about HP iPAQ h6315/h6365 Pocket PC
Switch on Hello, I have a HP pocket PC, which i am unable to switch on. I have charged the battery but still no joy. Any solutions on how to get it up and running. ( its a hand down from my family)
  • 25 Answers
Check that the battery is holding charge. If you are sure that the battery is working, try to do a soft reset or a hard reset to see if it wakes up. The battery usually has issues if it has been left unused to discharge for a long time.
Posted on Mar 14, 2008
I turn on the power switch, led lights, fan run, but after few seconds it turn off and no display on the screen, as in blank/ no lights
Hello ,
Check the battery,and the ampere.You did not explain about the company name and it is unable to
present next step about battery. you should better to go nearest technician, for test.
If your battery is fine Check the dc adapter,to cheek either charge the battery or not.
Dec 29, 2010 | HP Computers & Internet
My Ipaq rx3715 won't charge. "AC only"
its obsolete now, why use this thing?
wait for battery? then post?
or go to HP and ask them,
we are not HP, this is chat bs boxes here.
ever heard of HP? this is the official HP forum, try it?
If HP cant help you who can,
learn this ,when compelled to mess with obsolete products
buy 2 of them for like $3 on fleabay (most are in the trash now)
then mix and match parts, all day.
its obsolete, so doing tests on it lacking full spares is impossible.
why not buy a $3 used smart phone from same place,
Aug 04, 2017 | HP iPAQ RX3715 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
I have an HP Ipaq h1940 pocket PC. It won't charge!
Charge the dead battery with other good battery for a while first.
Jul 29, 2009 | HP iPAQ H1945 Pocket PC
Data missing - Ipaq model HP5555 - did not do hard reset
I'm sorry but the HP Ipaq 55xx series store data on a volatile ram based memory. Unlike a nand flash (like usb sticks, memory cards etc) this memory will hold data only as long as it's powered on. If your main battery gets empty you should still be able to retain your files for some 10-20hrs with the backup battery (if it's ok itself and not depleted). After this time the power to the ram memory is cut off and all data is lost.
The problem you face is somewhat related to that backup battery, as it appears it's unable to do it's job and maintain the power to the ram memory at least some 10 hrs. You should have that battery replaced.
There is no way to recover the data from the ram memory as it is stored as an electric charge over some memory cells in the ram chips. When there is no power, these charges dissipate and the pattern is lost.
I'm sorry for having to give the bad news.
Jul 03, 2009 | HP iPAQ H5555 Pocket PC
Basically my cell phone won't switch on
This is an old problem of Nokia 5310, sometimes, this phone will just automatically switch off. Please try this one:
1. Remove the battery of the phone and leave it for about 2 minutes.
2. Insert the battery and try to turn the phone on.
3. If you will get the same problem, you need to bring it to the authorized Nokia Care Center for firmware upgrade or repair.
NOTE: If the phone is under warranty, it should be free of charge.
Apr 11, 2009 | Nokia 5310 Cellular Phone
My HP iPAQ rx3715 turns off
I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. False contact on such back switch.
You need to find exactly where is located the switch that senses the battery cover lid.
It's located at the right/bottom side thru the battery bay. Check that there is not dirty or dust accumulated, causing that is sticky such area, which prevents such switch to work properly.
If you find nothing obvious, you can use small pieces of transparent tape (or masking tape) and put them on the internal side of the cover lid that is in contact with the switch (you have to locate first such area), put the battery and coverd lid again, and try to power it on. You can add a 2nd or 3rd layer of tape to depress such switch.
3. Broken cover lid. Check that is not broken in any part or corne rof it. If it's so, then replace it.
4. Defective switch.
Unfortunately is necessary to open the PDA and check with a continuity (or ohm meter) the performance of such swicth, which is easy but usually a technician does it.
You have the option of send it to be repaired, or try it yourself, which will require to buy a switch part, or pulled it from a PDA with possible working switch or the whole mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Jan 08, 2009 | HP iPAQ RX3715 Pocket PC
PDA will not display
is the battery fully charged.
has the phone dropped in water or some where else?
Aug 31, 2008 | HP iPAQ hx2410 Pocket PC
No power to Ipaq 3715
Just did this one, please refer to
For the solution
Jul 29, 2007 | HP iPAQ RX3715 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
HP iPAQ h6315/h6365 Pocket PC Logo
61 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
