Sony television-older generation
Dear Experts,can you help please?we have a sony tv model kv-m2521u in for repair-tho old its a tidy low hours set and hopefully worth repairing.The fault is a collapsed frame,however at the time of writing we have no circuit diagram or information.Iv taken a look inside and found a hefty diode/rectifyer board ref-d612 pt no-ctu12s with all3 legs badly cracked/dry-jointed alongside 2 hefty 2200mu caps these all look at a guess tobe in the frame circuitry-can anyone confirm or help further-any assisstance or circuit information greatfully recieved-Paul.
  • 3 Answers
Check preset of hight control and linarity control
Posted on Mar 04, 2008
Hi - my mom's sony tv - kv-27s42 ---- even after reading the manual I can not stop the closed captions from appearing - can you please help? Thanks! Tony
First, it is a older set.
Second: if the CC is coming from the set you will need the original Sony remote---Look under captions and either turn them off or to something other than CC1.
Third:If some kind of cable or other box is being used to supply signal to the set the CC can be coming from it! Yes, these boxes also have CC settings.
Look at settings in set first and in the box (if you are using one) second.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Sony KV-27S42 27" TV
Sony KV-27S65 27" Television suddenly has very low volume
that problem is very common on a sony tv,the sound IF and video IF of your tv is bad..video and sound IF is located near the tuner section of your tv.some sony model,the IF section and TUNER section are packed in one enclosure. it your tv sound IF is packed together with the tuner,then replace the tuner with a new one.some are packed separately so you need to replace just the IF module only..you can also try to adjust the IF by using a plastic smsll screw driver adjust the IF clock wise or counter clock wise untill you achive a good reception do it with the tv power is on..be carefull with the high voltage...
tnx and please rate my help..
Jun 03, 2010 | Sony KV-27S65 27" TV
Our Trinitron KV-36XBR400 powers up then no picture
How old is this tv?More than 5 years old.Not worth it to repair CRT tv at this prices.Tries unplug,replug an hour later,might help,see if reset itself.U can buy a pretty good 32" LCD tv at $400 or less these day.It not heavy as the CRT tv,it alot easier to move the tv around the house or other locations.
Feb 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Free TV Schematic
i repair a sony model KV-14RDR2 DEAD set but when i press the channel and volume button the l.e.d will blink please help me with my problem
Nov 13, 2008 | Sony Televison & Video
Sony TV Repair
crt going bad it is a common problem on sony old sets
Aug 06, 2008 | Televison & Video
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Old user manual sony tv KV-29ST1
I have a sony kv-27fs200 tv that takes a very long time to come on, about an hour or more.
Joel.
Jan 23, 2008 | Televison & Video
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KVTS27 audio noise and pops
your problem is a stand-up printed curcuit pcb it has several mof those small surface mounted caps that always goes bad and the # on the part is SBX1981or SBX1981-51p its part # is 874213400 its about 11 to 15 bucks . Dont try to repair the part as the pcb is eaten up from the caps leaking all over it. Good Luck
May 06, 2006 | Sony KV-27S42 27" TV
Televison & Video Logo
Top Televison & Video Experts
