I pulled this info from the manual. I am including a pic and the link. Hopefully this is helpful.
If you do not want to use the CLEARYL filter cartridge Blue, you will need to set the water hardness. The following water hardness settings are available: Water hardness Symbol(s) shown in display Level 1: 1-15 °dH 1 symbol illuminated Y Level 2: 16-23 °dH 2 symbols illuminated Y < Level 3: 24-30 °dH 3 symbols illuminated Y < > & T Touch the Descaling symbol. The Y, < and & symbols light up. T Touch the Y, < or > symbol to set the water hardness, e.g. symbol Y for 'level 1'. The Y and & symbols light up. & T Touch the Descaling symbol. The Water Tank symbol M lights up. T Place a receptacle under the coffee spout. T Remove the water tank. T Fill the water tank with fresh, cold water and reinsert it. The Y, < and > symbols flash. The system fills with water and the water flows directly into the drip tray. The operation stops automatically. The machine heats up. The Y, < and > symbols flash. The machine is rinsed, water flows out of the coffee spout. The rinse stops automatically. The Ristretto Y, Espresso < and Coffee > symbols and the symbol for 'strong' coffee strength _ light up. Your ENA is ready for use.
Press the 'mode' button on your remote until it says 'cool' or shows a snowflake symbol. Careful that you don't set it to 'heat' mode accidentally if it only has symbols. The 'sun' (heat) mode symbol can look like a snowflake on some of these remotes. Then set the temperature to suit you.
In your remote, there is mode button, the symbols for each option will display. The symbols are:
Now symbols: 1. fan leaves - Fan only 2. Rain drop- Dry mode 3. Snow flake-Cool mode 4. Sun- Heat 5. A or AU- Auto mode.To get proper cold air set temp 23 degree and mode"cool". To get heat set temp minimum 3 degree more than room temp and mode in "Heat"
Symbolsin remote:
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Check wiring done correctly. Symbolsin remote:
Helpful?
Symbolsin remote:
Symbolsin remote:
Now symbols: 1. fan leaves - Fan only 2. Rain drop- Dry mode 3. Snow flake-Cool mode 4. Sun- Heat 5. A or AU- Auto mode.helpful?
PLEASE GIVE CORRECT MODEL #
http://www.dhgate.com/product/gree-air-c...
