Ink spray on printed photo
Hi, i am having a problem with ink droplets on my prints, i have done a full maintenance job as instructed by manufacturer..HP..3210 ALL IN ONE..i am also using HP photo paper, could it just be that i have an iffy cartridge?
  • 75 Answers
Can u dis assembly ur printer if yes
just removed the gear mechanism and clean the gear.
Posted on Mar 04, 2008
Epson t60 is good printer ?
Hi global_sreek,
EPSON is Super fast, affordable & powerful for all your professional photo printing needs.
Features
Increase your productivity with super-fast print speed
• Print instantly from your computer screen at a fast print speed of 12 seconds per 4R photo
Maximise savings with Epson INKdividual™ Cartridges
• Maximise savings and minimise wastage by replacing only what you need
• Epson 6 colour photo ink is highly affordable, keeping daily running costs low
Perfect printing onto CDs / DVDs
• Print directly onto the printable surface of your CDs/DVDs
Compact size to fit any space
• The Epson Stylus® Photo T60 is so compact, it takes up little precious studio space,
freeing it for other uses
Photo perfection with Epson Creativity Suite
• A powerful photo editing software that lets you perfect your photo prints with just one
click of a button
SPECIFICATIONS
Print:
Ink System - 6-colour
Ink Type - Photo Dye(??¥?œ¬??ž?®??š??¼??¸????₪œ?´¢ )
Max. Print Resolution - 5760x1440 dpi (with VSDT)
Min. Ink Droplet size - 1.5pl
Print SpeeD - Approx. 37ppm (Black) Approx. 38ppm (Colour)
Connectivity and Compatibility:
PC-less function - No
Index Sheet - No
Connectivity - Card Slot - No
Connectivity - USB Cable - Yes
Connectivity - Wireless - No
Interfaces - USB 2.0 Hi-Speed
OS Support - Windows 2000/XP/XP-x64 Edition/Vista Mac OS 10.3.9 or later with USB
Network - No
Adobe Postscript - No
Memory Card Backup - No
Ink Cartridges:
INKdividual - Yes
Ink Cartridge Model - 85N Ink Series (Standard Capacity)
Media:
Media Model - S041926E1; S041927E1; S041863; S041464E1; S041285; S042070; S041925; S041332; S041786, S041259
Paper Handling:
Max. Paper Size - A4
BorderFree - Yes
Max. Paper Capacity - 120 sheets
Roll Paper - No
Tractor Feed - No
Cartridge Model(s):
85N (Standard Capacity Black Ink) - Approx 540 pages (ISO/IEC 24711 and 24712 Test Suite)
Page Yield (pages):
85N (Standard Capacity Colour Ink)* - Approx 860 pages (ISO/IEC 24711 and 24712 Test Suite)
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Epson TM-T60 Printer
Printing lines on the photo using bulk ink
Good Day!
Please follow the instructions:
1. open a blank document (word,excel,) 2. control P 3. under printer properties hit on maintenance tab. 4. then hot on head cleaning. once done, "print check pattern" 5. please continue doing this until the print out goes clearer. 6. then, try to print. i hope this helps.
Jul 20, 2011 | Epson Stylus R290 InkJet Printer
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
Epson Stylus Photo R200 prints red lines under all the print (not the whole page, just the printed part). This includes pictures.
maybe its out of ink.
if still full then
perform this instructions.
click settings, printer and faxes, then right click of the printer device you are using. then click properties.
click the maintenance botton on the upper right then click cleaning botton..
repeat until the printing goes back to normal.
Sep 25, 2010 | Epson Stylus Photo R200 InkJet Printer
Printing black horizontal lines below text/on top of pictures
Check the waste recepticle under where the ink cartridges rest in the home position. Over time, ink sprayed into this cup during cleaning cycles builds up to form a small mountain of congealed ink. If this gets too high, it makes contact with the printhead and drags ink across all your prints. If there is a ***** of ink present, scoop it out with a spoon or a popsicle stick.
Dont get it on you, its messy...
Jun 22, 2009 | Dell 924 All-in-One InkJet Printer
Waste ink absorber almost full. What do I do?
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
May 04, 2009 | Canon I960 InkJet Photo Printer
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Hi I have just inserted a new HP ink cartridge 94 into my HP PSC 2350, as the ink was running low. I was printing photos, which keept printing with a red line throughout the picture. After inserting the...
Try opening the printer properties and cleaning the print heads (should probably be done each time a cartridge is changed), it uses some ink up but should clean the build up from running the previous cartridge dry and hopefully solve your printing problem.
Good luck.
Mar 29, 2008 | Computers & Internet
Faded print job
ok...have you tried a clean and re calibrate lately on those print heads?
Mar 20, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Oct 19, 2007 | Canon i9100 InkJet Photo Printer
55 people viewed this question
jasbo
jasbo
