Question about Samsung 710V 17" LCD Monitor
Not optimum mode 510v 17" LCD Monitor
I try the first solution which is adjust the screen resulotion in the control panel settings,but it theres nothing happen it still flashing the "not optimum mode recommended mode 1024x768 60hz?"...what the second solution it might be???tnx a lot...mwahhhhhhh
  • sugarft Apr 18, 2008
    Whenever I turn my computer on the screen is black with this floating box that has a message inside saying Not Optimum Mode Recommended Mode: 1280x 1024 60Hz. Under that message is a yellow box with a question mark inside. What should I do. I cannot do anything, I've pressed every button on the keyboard, and nothing happens. Please help. Thanks Pat
Samsung have a lot of liquid crystal display there. The solution is simple: the replacement of an MCU will be able to repair.
Samsung LCD MCU sales:
http://www.dgdw.cn/lcd%20mcu/SAMSUNG%20MCU%20English.htm
SKYPE: cqrising
Posted on Dec 07, 2008
Well, you need to change the EEPROM on the AD board.
Posted on Mar 16, 2008
Screen size reduced horizantally at the ends,even monitor controls are adjusted maximum.
You will have auto adjust button in ur monitor! if you have that, try pressing that button. It will set the the monitor resolution to the optimum level.
Aug 01, 2010 | Philips 170S5FS 17" LCD Monitor
Screen stating not at optimum mode requesting 1280x1024hzm i have raedeon video card
Samsung syncmaster 170n monitor shows black with screen stating not at optimum mode requesting 1280x1024hzm , how do I fix this?
Oct 15, 2009 | Computers & Internet
Cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | AOpen Black 17" CRT Monitor
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Monitor turns black and with a not optimum mode pop-up
Press F8 when you boot your PC, Then boot on SAFE Mode...
Right Click on Desktop>>Properties>>>Settings>>>Advance>>>Check the Apply the New Setting without restarting.
Click Apply then OK
Rebbot the computer to a Normal Boot
Oct 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'.
Sounds like you have an LCD monitor. LCD monitors look best in their native resolution. Yours must be 1280x1024. You need to (assuming this is a Windows PC) right click on the desktop and choose Personalize, Display Settings (Vista) or Properties, Settings (XP or older). Set the slider to 1280x1024. It'll confirm the change and then the message should never reappear.
Aug 28, 2008 | Computers & Internet
Cannot display this video mode optimum resulotion 1280*1024 60hz
Chances are that the video driver for XP and 2003 differs (even if only slightly). You might want to start the 2003 in "Safe Mode" first to lower both the Screen Resolution and Screen Refresh Rate to the lowest possible. Thereafter do an update on the video card driver compatible with 2003 from the Dell.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Not optimum mode recommended mode 1024 x 768 60hz
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Showing "not operating in optimum mode"
reinstall the display drivers in safe mode this you can do by pressing F8 and in safe mode, you can also try restoring the machine to previous state Good Luck
Jan 19, 2008 | Samsung 710V 17" LCD Monitor
Samsung 710V 17" LCD Monitor Logo
250 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
