Furniture Logo
Anonymous Posted on Mar 02, 2010
Nobody has answered my question!
My whisperkool 4200 cooler, does not properly cool. I have had it two years with no problem. I noticed the on/off switch is blinking. the unit has not frozen and is not dripping. It however does not cool below 63. I signed up for the 19.99, but have not heard a response to my question.Thanks for any assistance you can give me.Steve
Anonymous
Level 3:
  • Master 715 Answers
  • Posted on Mar 02, 2010
Anonymous
Master
Level 3:
Answers
715
Questions
Helped
151317
Points
1931
Check freon and fan motor and maybe your thermostat
I need wiring diagram for whisperkool 4200 xlt
Not available. Contact the maker
WhisperKOOL ' Wine Cellar Cooling Units ' Manufactured In ...
https://whisperkool.com We provide the most innovative wine cellar cooling units for wine cellars in the industry. Protect your investment in fine wine with a quality product...
Shop · ‎Contact Us · ‎Ceiling Mount
How To Contact WhisperKOOL Customer Service Telephone (209) 466-9463 (800) 343-9463
Fax (209) 466-4606
Website www.whisperkool.com
Address WhisperKOOL
1738 East Alpine Avenue
Stockton, CA 9520
Whisperkool 1600 xlt developed a drip from the right fan after many years of trouble free operation. What could be causing this?
http://www.luxewinecellars.com/sites/all/files/product_downloads/whisperkool-xlt-owners-manual.pdf
i was just reading the manual for you. This make not be the exact manual But once a year you have to clean the fins, bleach the inside etc. make sure the drain hose is not blocked with goo, or deposits etc.
Oct 20, 2013 • Furniture
My wine cooler is making a loud humming noise. It still cools fine, but you can hear it throughout the house now.
possibly the compressor is running harder due to either being low on freon or the condensor coils are dirty not letting the heat to be released causing the the compressor itself to overheat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
My unit is running but not cooling. the fans in the back of the unit are not turning and discharging hot air.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
The Whisperkool 4200 unit is no longer cooling the wine room. The digital display is jumbled and will not reset when unplugged. The fan runs constantly but the wine room is only be cooled to 64 degrees. I...
Version:1.0 StartHTML:0000000149 EndHTML:0000001329 StartFragment:0000000199 EndFragment:0000001295 StartSelection:0000000199 EndSelection:0000001295 All WhisperKOOL units come with a 2 year parts and labor warranty with a 5 year warranty on the compressor. During the warranty period, if the unit fails a replacement unit is sent at no cost to you. If your unit fails after this period we offer a Consumer Care Program to give the customer a chance to get a new unit at a deep discount. In many cases, the failing unit has been misapplied and the correct unit for the installation is sought after during the replacement process. Our customer service department is trained extensively, with live customer service representation with a streamlined process for not only helping with the products, but also assisting in identifying any limitations to the installation or ventilation of the cooling unit.
If a repairing the unit is the decided route, call WhisperKOOL directly at 1-800-343-9463 and parts can be ordered depending on availability. A knowledgeable HVAC Professional should perform any repairs due to the refrigeration system.
1helpful
A layer of ice forms on the unit. Checked & replaced thermostat
here's the deal. unless you have a license to purchase freon you can't. Most likely the unit contains r-22 freon unless it was made before I think 1987 if made before then it is more than likely r-12. The reason appliance techs do not want to do this is because of the intensive set up in orderto access the system to add freon. they have to weld connections to access the freon and in such small areas it can be a massive pain. I would contact Whisper cool and see if they have any service centers in the area where you can take the machine for repairs.
Good luck hope this helped
Dave
1helpful
Whisperkool 4200 icing up
Hi, Bob:
Misery loves company, so I'm posting this even if it isn't in time to help you.
I had an XLT 8000 with similar problems. Vinotheque wanted to do the exchange program ($2,500+), and I was told the older aluminum coils might have leaked, and the exchange models come w/ SS coils. I was near to biting on that, when I decided to have a local refrigeration shop check it out.
Here's what they found--A MANUFACTURING DEFECT. It seems there are small copper capillary tubes that circulate the refrigerant. If they touch each other, with normal operating vibration they can wear holes in each other and the refrigerant can leak out. The leak can be very slow. According to the guy who fixed it (all for $219, and much of that was for drilling out the riveted-closed enclosure), "crossed cap tubes" is a Bush League mistake, akin to not putting oil in your car's crankcase.
I'm not saying WhisperKOOL/Vinotheque did this on purpose, knowing there would be an eventual failure and an opportunity to make another sale. But what the service guy told me was that IF the manufacturer was without scruples, a crossed cap tube would be the perfect way to take advantage of an unsuspecting customer.
My fix? Drill out the rivets, and find a local qualified service tech. Fixed in hours for $219 or in weeks with an exchange for $2,500... You choose.
2helpful
Ice is forming on the outlet holes on the face of my 4200 xlt
you should check to see if the fan at the back of the unit is operating, and you also need to check for dust build up, if the fan is working then clean and defrost the unit, try it again, make sure there is nothing blocking the airflow, if the motor is not running, replace the motor, hope that helps
1helpful
Cool air outlets frozen over with ice
And the temperature hasn't changed at all (still set at 55ºF)? A troubleshooting guide says you can check if the cause is because too much heat was lost to adjacent areas, and you can try to add more insulation around the ductwork and ensure doorways and glass panels are sealed. Other than that... not sure. If it's older, maybe you can look into a new Whisperkool split system or cooling system (there's some great ones on http://www.vintagecellars.com).
Top Vinotheque Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Vinotheque Furniture Expert? Answer questions, earn points and help others
