Akai cdr-160w how do i inicialise the cd so that i can record onto it?
    Master:
  • 518 Answers
I assume it's a blank cd-r or cd-rw disc.
Just write to it with a software progrma like Nero.
Geno
Posted on Mar 04, 2008
Why can I not record to a CD from the "aux in" port?
Your question has not provided enough information. Are you trying to record vinyl onto a cd?
You cannot record onto a normal cd player. You need a cd burner(/recorder).
Vinyl turntables have a quieter output signal too so unless you have a device that has a phono (vinyl) input you will not be able to record your vinyl. If you have a laptop then the easiest way to record vinyl onto cd is to buy a soundcard that has phono input. You can then use free software (programme) like audacity to record your vinyl and covert it to a format (wav aiff or mp3) to burn to cd using iTunes or Windows Media player.
Sep 27, 2014 | Audio Players & Recorders
Does anyone know if it is possible to record from a DJ mixer onto the Yamaha CDR-HD1300 CD Player / Hard-Disk Recorder? -- i.e Can I record a live DJ set straight onto CD? And/or can I record a live set...
The recorder could not care less what the upstream audio device IS or if it's live vs prerecorded as long as the connection works and there is a signal.
Jul 21, 2011 | Yamaha CDR-HD1300 CD Recorder
Recording
You can only record from the radio or CD player. There's no microphone input on this model. Just insert a tape and press the REC button. If you're recording from the CD, it begins playing when you press the REC button. If you need a copy of the manual you can download it here.
Mar 28, 2010 | Aiwa CSD-TD31 Boombox
How do i put my music onto a cd? every
Often when recording music CD's you must "finalize" the CD so that the header info of the tracks are written and available to the player.
Sep 19, 2009 | Boss Micro BR Digital Recorder
How to record from tape to cd
It is not possible to record onto a cd as the unit is only fitted with a cd player not a cd recorder.
To record from tape onto minidisc, just press the record button on the main unit whilst listening to a tape.
Jul 15, 2009 | Sony DHC-MD333 Shelf System
Not able to record onto Adobe Audition 1.5
Sounds like you do not have your audio recording source set correctly.  If you're recording from a file on your computer or a CD via the CD-Rom drive of your computer, you need to probably set the recording to either "Wave" or "What you hear", one of the two.  The "What you hear" can be easiest, but then again, if any other sound comes accross your computer at the same time, you'll end up recording that as well, so it's best to stick to "wave" if you can... or make sure all Windows sounds are turned off (Audio settings ->Sounds ->Select "No Sounds" as the theme).
Oct 25, 2008 | Adobe Audition 1.5
Tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Oct 20, 2008 | Tascam 2488 Portastudio Multitrack...
DVD ROM/CD-RW Drive
try to roll back the driver , if that doesn't work go to the manufactures web site and download the driver . if it still doesn't record install the drive in another computer and if it doesn't work then it maybe a bad drive itself
Aug 06, 2008 | Gateway 310S (2900621) PC Desktop
Buring CDs
Install a software for recording and write with Nero as a data cd.
Oct 02, 2007 | Toshiba ZA2055P08 - Satellite 1800 24X...
107 people viewed this question
 Grubhead
Grubhead
