Question about Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius wd420
Is there a filter on this model for the drier, have not got a manual for this model and can't locate one on the Hotpoint website. If there is a filter can someone PLEASE tell me where to find it on the machine?
Drier is only working for only half an hour before cutting out and won't let me have my washing back so thought it might be a filter blocked unless someone else can give me a better explination? I am now very frustrated with this machine.
  • jennasteg Aug 25, 2008
    the drying part of the machine will not work were is the filter
Hi i have a hotpoint aquqaris wd420, that just won't do anything.It was working fine and then i went to put on a new load and it does nothing, expect to **** in some water for a second and then stop. i cleaned the filter and can see no burning on any of the boards or connections. and no warning signs or flashing lights.
can anyone help
ryan
Posted on Sep 19, 2011
Filter is accesible via a plastic panel on the back. Un-plug the machine, unscrew the cover and you will see a large black rubber funnel. The filter is in there. Loosen the metal ring with screw driver (remember to put a basin under it). Remove gunk etc. Replace everthing and see if it helps.
Posted on Mar 27, 2008
That link is broken! I have the same problem, I need to locate the filter in order to get dryer to work. HELP!!!
Posted on Mar 16, 2008
  • 121 Answers
Posted on Mar 04, 2008
Changing filter
Where is filter on Hotpoint Aquarius WD420
Oct 14, 2012 | Hotpoint Aquarius WD640 Front Load...
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Nov 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint aquarius wd420 cannot stretch drive belt on there is no slide bar on motor which is fixed solid even after bolts are lossened its a washer drier no obvious way of attaching belt
There is no adjustment provided for tensioning belt as it is a stretch belt.
Best way to do it is to remove the rear panel, tilt the weaher forwards, get someone to hold it for you.
Put belt round motor pulley first, then slowiy feed it round the drum pulley, turning the drum pulley at the same time, it will be very tight, so watch your fingers, just keep going until belt is on, if it comes off, just start over
You can line it up properly in the motor pulley grooves once you have got the belt on.
Please rate my solution.
Thankyou.
Feb 25, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine very noisy when it spins. Missing bra
If you cannot here it catching, then leave well alone, if it is still catching, then you could to try to locate it by removing the lower rear cover of washer, remove the large black hose on bottom of drum, and see if you can locate it from the bottom of the drum.
Hope this helps.
Jan 16, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint wd420 not pumping
Hi,I have just been on a service call to the same model,the pump windings had shorted turns and after replacing the pump i have found that it has also damaged the module(pcb assembley) not good considering the module is 120 uk sterling!!
Feb 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Feb 08, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Removal of door seal on hotpoint washer drier wd420
You will achieve nothing by removing the door seal .
Depending what is in there, better to leave alone and trust it will find its way into the filter.
If it is anything substantial then it involves major work.
Dec 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA56 Front Load Washer Logo
1,528 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
