Question about Polycom VSX 7000 Video Conference
VGA Output resolution
Hi
After first configuration VSX 7000 i have a problem with output resolution on monitor and so i can't see homepage and configuration menu to fix it. I changed few monitors and i think problem in settings in VSX. How can i do hardreset to factory defaults?
  • 47 Answers
If it has an IP address connect to it using a computer on your network.
Posted on Apr 08, 2008
My videocon tv having automatically av/tv switching problem what is its solution
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 09, 2014 | Polycom VSX7000 Videoconferencing System...
How solve in my POLYCOM VSX 6000 showing error "unsupported signal adjust your PC output"
Try using the S-Video output and then try using the VGA output from the VSX 6000 unit. The unit can be fixed to output from either as the first monitor output (you may have the dual monitor option enabled). If this does not work the resolution of the TV might be HD, the output of your VSX 6000 is Standard Definition. You will need a monitor that accepts standard definition. If this does not work, I would reboot your VSX 6000 and try again. David
May 17, 2014 | Polycom VSX 6000 (220022222001) Video...
No AGC output,not normal colour
Pls can you ellaborate more on the problem...
Apr 12, 2014 | Polycom VSX7000 Videoconferencing System...
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
VSX3000 for dual display
u need to activate dual video & also configure the monitor 2 output ( i.e VGa or some other video out) monitor 1 & monitor 2 cannot be the same
also check if u have activated the function using the software key provided by polycom
Jan 12, 2009 | Polycom VSX 7000 Video Conference
USING MONITOR AS A TV
Use a HD set top box which has VGA output.
Ensure the STB will output at a resolution and scan rate to match that of the screen.
Mar 01, 2008 | Acer AL1916W 19" LCD Monitor
Help me
Power on unit, press and hold * key on remote takes a few minutes but spinning polycom logo will appeara and a minute or two after that the menu screen comes up. Main output is configured for S-video, your seeing a 2nd monitor output, doing above will switch the VGA to be main output.
Jan 16, 2008 | Polycom Small ClassStation VSX 8000...
Screen resolution
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console.
Change your display output settings from this screen. Display settings include screen resolution and screen dimension (or aspect ratio, either standard or widescreen).
In some cases you can select an "Optimal Resolution" button, which appears only when Xbox supports the native resolution of the TV or monitor and automatically applies the best setting but that might not work with your tv.
If you are using VGA you must choose from among the following output resolutions: 640 x 480, 848 x 480, 1204 x 720, 1280 x 720, 1280 x 768, 1280 x 1024, 1360 x 768, and 1920 x 1080.  Much like a PC you would want to select a lower resolution (640X480).  That will make your fonts larger.
Screen Format: The default setting is Normal (a standard 4:3 aspect ratio); select Widescreen to change the output aspect ratio to 16:9 if you have a widescreen TV or monitor.  You should select normal and not widescreen for a standard tv.
Hope this helps,
Bob
Dec 26, 2007 | Microsoft Xbox 360 Console
Can't get to the home screen
I've just solved that problem in the VSX 7000 of my girlfriend's Job.
Your VSX7000 has at least 4 video outputs, 1 for VGA and Supervideo 1 and Supervideo 2.
Firstly you should try VGA connector, because the main menu may be there, so you could change the configuracion.
If you can't see main screen in any of the output connectors you'll have to use the http tool.
In your internet browser enter the camera IP address, and you'll get the Web Interface of the VSX7000.
It will prompt you for user & password, the default options are "Admin" and your VSX7000 serial number (14 digits) you can find this number under the camera.
Once you're in the Web Main Menu, click on Site Map. There you can choose what you want to see in the screen of Monitor1 (My menus are in Spanish, maybe your menu says something like "screens" but I'm sure you'll find it)
If you choose Monitor/Screen 1 as Svideo, and select it as output for Local, Remote and Content you should see the Main Menu after the VSX7000 Reboots.
I hope it would be useful for you, if you have any problem with this let me know... This VSX7000 is working fine now, so yours should work!
Sep 19, 2007 | Polycom VSX 7000 Video Conference
Polycom VSX 7000 Video Conference Logo
359 people viewed this question
Top Polycom Lands Phones Experts
David Burbee
David Burbee
TEKUSER
TEKUSER
pankaj rautela
pankaj rautela
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
