Help???? how do i connect up a pioneer premier 2000 watts sub?
  • 40 Answers
Spaduec- First of all,I need to know,what your hooking it to.Are you going to hook it up to an amplifier,say in a car.If you let me know what you have and want to do I'll help you out.
cooltek Mar,4/08
Posted on Mar 04, 2008
I can't figure out if my crunch powerzone pzi 250.2. 1000 watt amp is compatible with my 2000 watt pioneer premier 12" sub, I seem to be blowing fuses will someone please help me out
There may be an impedance mismatch between the two. If the amplifier "sees" a load impedance of 2 ohms or less, for example, the fuse(s) will open to protect the output stage from failure.
Feb 09, 2017 | Pioneer Car Audio & Video
Subs are smoking
You have officiqlly burned them out by creating a short insid of them
Feb 26, 2013 | Pioneer Premier TSW-3002D4 12 Inch...
How to wire the Pioneer Premier 12in. dual 2 ohm voice coil. 1000 watt rms 3500 watt peak, and I have a 1000watt JL audio 2 channell amp, they are both stable at 1 ohm. I wired them parrallel, and it blew...
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
May 09, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
The fuse from the amp to the battery keeps burning
maybe it cannot accomodate too much power running on it...too much current, try another fuse with higher ampere rates
Jan 14, 2009 | Nitro BMW-486 Car Audio Amplifier
Premier sub used to work great ... now nothing
Did you check to make sure that you didn't blow a channel in the amp? Another thing to check would be the connection on the inside of your box, maybe there is just a wire loose.
Dec 19, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Amps
It comes down to Amperage and RMS, your best bet is to go in and talk to a salesman at a stereo shop. That way he can decide on what sort of power you want and how you wanna use the subs. But 1000amp AMP is probably a good start 4 channel of course. Alpine or SOny make some kick a$$ AMPS
Feb 17, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Lights dim
3000 watts divided by 12 volts=267 amps...how hot is your alternator...have you considered a separate alternator or a battery isolator?
Jan 09, 2008 | Pioneer PRS-D5000SPL Car Audio Amplifier
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
24 people viewed this question
 Grubhead
Grubhead
