RIM BlackBerry Bold 9700 Smartphone Logo
Posted on Mar 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't pair my plantronics 510 BT earpiece to my new bold 9700. but I can pair to my old BB and can pair other stuff to the 9700, so know that both devices work...just not together.
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Mar 22, 2010
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882374
Points
4663
You might want to check which version of the the BlackBerry system software you are using.
Having the latest version will ensure that you are running a platform with as many bugs worked out as possible.
This page will provide a link to the latest multi-language version of BlackBerry System Software.
Want to know the difference between GETEL Bold 9700 and the BB Bold 9700.
the Bold 9650 has a somewhat larger bezel VS the 9700 Bold. Other then that nothing else is different .
Feb 14, 2011 • Cell Phones
1helpful
New blackberry bold 9700 will not accept bluetooth from other phones
Blackberry BT File Transfer is a little different than other handsets. when your wanting to receive a file transfer goto 'MEDIA' , select the type of media (picture, music, etc) click the 'BB Button' to get more options, and select 'Receive using Bluetooth' and then have your friend initiat the BT file transfer
hope this helps
R
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
I can't pair my BB bold 9700 with my Porsche Cayenne S PCM system
post your e-mail address & I will mail you the relevant pdf file as an attachment ok
2helpful
I am unable to receive pictures, music from other mobile phone to my BB Bold 9700 through Bluetooth. Both devices are pairing but BB is not receiving sending is not a problem.
you should select the option "receive via bluetooth". in the media menu, press the menu button (the bb symbol) then select receive via bluetooth, then send the file. you will then be able to receive files from other phones.
hope this helps. also please rate. thanks!
BLACKBERRY 9700 BLUETOOTH CONNECTIVITY
in the media menu, press the bb button then select receive via bluetooth
3helpful
2answers
How do i put my 510 earpiece in the pairing mode
Press and hold the switch for about 30sec ...after that it will be in pairing mode ...and enter 0000 as passkey
Old voyager 510
There is no need to reset your old bluetooth device. You should put the device in pairing mode so that it can be detected. once you have that set up you can register it on your old device and your new device. I had my bluetooth device on 3 different phones! You can pair your headsets with more than one phone. Questions, get back to me!
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Earpiece slipped off the plantronics bluetooth,and i want to know if there is anything to help put it together again.
my plantronics 510 voyager did the same thing. try putting the earpiece back on to the main bluetooth and wrapping a small rubber band BETWEEN THE TWO. the object is to put some opposing pressure on the earpiece to force it to stay on. it'll work at least till you get anoter earpiece
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
