Question about GE DBSR453EBWW Electric Dryer
Cold stopped working
The cold water stopped working but the hot water does
  • 26 Answers
Check the strainer in the cold water inlet line. Make sure it is not plugged. Then,put the cold water line into a bucket and open the valve slowly until water comes out. If water flows freely, it's probably the cold water solenoid. It's pretty easy to replace.
If not, check all valves upstream, check for a collapsed hose, or mineral build up in the pipe (galvanized pipe)
Posted on Mar 04, 2008
Hot water in kitchen only froze
good idea to let the cold water to run a bit to stop freezing up . Pity that you didn't do the same with the hot water. There is only hot water in the tank but the water in the hot water pipes will freeze as the heat goes out of the pipes. (Always to have to wait for the hot water to come through when you use the shower or bath.) The water will freeze up right back to the hot water tank
Jan 29, 2014 | Cars & Trucks
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Hot water stopped working Cold is OK
may be the new facuet see if the hose is clogged detach it from the sink turn on the water and see if it comes out into a bucket if it does than its your new facuet
May 12, 2009 | Plumbing
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
Mixer tap makes a noise like a fog horn when cold water turned on
Usually happens when the stops and not ballanced(hot and cold pressures going to the faucet). Try ajusting the stops; open more on the hot or close more on the cold.
Feb 04, 2009 | American Standard Plumbing
No hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
GE DBSR453EBWW Electric Dryer Logo
96 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
