Question about Garmin StreetPilot i3 GPS Receiver
Motorola Flash Mode fix
I have the exact same problem. This happend to me after I let my battery run all the way out. I charged it up and when I tried to turn it on and got the following message:
Motorola Flash Mode
Bootloader Version:
BOOT_C_03.08.00R_MPAP
What a wasted site, nothing posted here is any help... I was looking to download a user's manual and all I see is people complaining about there MP3 player without any helpful information...
Posted on Apr 26, 2008
The same thing just happend to me.... this is wack
Posted on Apr 19, 2008
2 Suggested Answers
Boola-Boola
  • 8 Answers
SOURCE: Motorola Flash Mode - bootloader
Hmm - that kind of message is most likely the basic boot loader in the unit getting activated, this would normally be used in manufacturing to get the 'product firmware' (the programme that makes the product do what it does) into the unit on the production line.
For this to be appearing in customer hands I'd suggest that the product firmware has gotten corrupted. Being unable to run the product firmware the unit is entering it's bootloader and expecting new firmware to be put into it.
Unless your product manufacturer's support webpages have firmware downloadable for the product, along with details of how to do it, then i'd suggest that your unit probably needs the attention of an approved service centre or manufacturer service department.
If the product is still under warranty then the warranty may cover fixing this fault - check terms and conditions and/or contact the manufacturer or the store you bought it from - you may get it fixed free or replaced under warranty by the manufacturer or the retailer.
If it is out of warranty then it may likely cost something to get your product repaired, but it's probably worth making enquiries - a repair may be worthwhile but you'd need to find out cost. It may be worth contacting the manufacturer and asking if this is a known common issue with this product - if it is then they may have put a mitigation plan in place to support users that experience it and if so this may be available even if the unit is out of warranty.
Hope this helps y'all to understand the message you're seeing on the display. Would be interested to hear if you get it sorted.
Cheers,
BB
Posted on Jan 05, 2008
Tip
Flashing motorola phones without a battrey
if you have a dead battery and you want to flash your Motorola phone and you cant do that cause your battery is dead . well i have a solution for you guys . all you need is all usb cable and Motorola rsd lite 3.7 or better now. OK no battery needed remove the battery , on the device hold down the # * buttons than plug in the usb while holding the # * and that should put the device on flash mode that hit start and let the phone flash itself and after its done passed flashing go ahead and insert your battery on the phone and let it charge by it self , easy trick and a tip for the flashing software guys ........good luck from ...rymi1982
on Jun 17, 2010 | Cell Phones
How to get flash mode off a phone
How to fix Motorola Flash Mode Of Death To do this you must have a fully charged batery, i know when your phone is stuck in flash mode you cant charge your battery so your gonna have to buy a new one or try to charge the battery i another phone.
First download Motorola RSD Lite 3.2 from here http://www.cpfxwireless.com/downloads
Then download the Monster flash file from here http://www.cpfxwireless.com/downloads (Same place i no)
Then extract your monster flash file, save it to somewhere on your computer.Plug in your phone when on motorola flash mode .Open RSD lite , find your monster flash file wherever you saved it then click on start. You can always use the Motorola Software update , but i already had the latest software on my phone so there was nothing to update
Jun 29, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Help ME!!! V3i dead Now!!!!
Once you flash the v3i to R441D you cannot go back to R397 but if you power on phone while holding down # and * you can go into bootloader mode and then use FlashBackup to re-flash phone with R4441D firmware. I have had this issue a few times and always been able to recover it. If this doesn't work locate someone in your area via google or craigslist that offers Smart-Clip service and they can fix it for you.
Jan 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Motorola q verizon Flash Mode fix
1 remove battery
2 clean you contact , include all connector tooth brush alcohol's
3 make power up
4 if not fix u need install new internal software .
the problem's come out , when u get water infiltration
good luck
Mar 12, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola W180 Driver
Here is USB Drivers installation procedure for Locosto USB based models :
  • Run "Motorola Driver Installer.exe" from "C:\Program Files\Common Files\Motorola Shared\MotPCSDrivers\" dir
  • Select "Clean only" and press start, wait untill its finished then close the software,
  • Open Control Panel, Add/Remove Programs and uninstall Motorola Drivers
  • Open Rocker Dongle Support, and navigate to ".. / .. / RockerDongle / Drivers / W156i_W160_W175_W180_USB_Drivers / dir.
  • Download and install "Motorola.9.0.msi"
  • Restart PC
  • Connect above mentioned Motorola model with mini USB cable to pc, with battery removed
  • Insert battery, windows will detect "LOCOSTO" device and install drivers
  • Remove and insert battery again, and check in device manager for "Motorola Flash" device.
If You have done everything as described, You will have installed drivers correctly. Take note, these models will remain in flash mode for only 5 seconds, if no comunication started, phone will go to charging mode.
Feb 26, 2008 | E-Machines W1800 PC Desktop
Motorola Q
Have you tried removing the battery? That is usually the first step on this type of problem. Has the phone been damaged in any way? Liquid dropped etc? Any of those may also play a part. If the phone is still covered by warranty the best bet may be to take it to your local service center if taking the battery out does not fix it!
If you have any trouble feel free to contact me ill be glad to help!
Feb 19, 2008 | Motorola Mobility Moto Q
Motorola hs820
I am having the same proble too..I am going to open it up and see if I can fix it, I'll keep u guys posted...
Blazemorefire..
Oct 09, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola flash mode
Have you tried a Master Re-set when the phone is off? Hold the center key and the power button for at least a FULL minute to a minute and a half. You will see the provider's splash screen, but hang tough.
This works best with the device on a flat surface rather than holding it.
Sep 16, 2007 | Motorola Mobility Moto Q
Doesn't turn on!!
you need to try and get into the boot loader to see if you can flex/flash it from there. a new flex should solve the problem, unless there is physical or water damage to it. It could also be a defective battery. Are you positive the battery works? Did you do any kind of upgrade on the phone? played with it's firmware? On flashing - http://wiki.howardforums.com/motorola/index.php/How_to_flash_with_RSD_lite Flexing is done the same way Good luck
Jun 24, 2006 | Motorola Mobility V710
Garmin StreetPilot i3 GPS Receiver Logo
249 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
