Question about Tektronix Refurbished Phaser 560 Color laser printer -29119
Tektronix Phaser 560 error 33 / transferkit error
4 some days my printer shows the message above. I found in the net a solution to clean a clutch on http://www.fixyourownprinter.com/?search=forums&q=Tektronix+Phaser+560+and+740 but - unfortunately this does not help.
The paper comes out only a quarter of the sheet and there is only printed some lines on the top and the message occur. Sometimes the paper comes out completely but also with few lines printed, few seconds later the message -> error 33 transferkit error is on the display.
I have removed the transferkit and the whole machine is clean. In the mechanic there is no hard point whenn moving manually, too.
All serviceable parts are in their normal lifetime.
The machine does always a goot job and the counter is about 60k pages. I do not want to replace the machine........ - especially there are mostly new cartridges in!
Please give me a hint...............
  • pohl-mau Jan 18, 2009
    I Have the same problem as listed above and my paser has only 3.500 pages. Has anybody a solution for this problem ???
  • Anonymous May 24, 2009
    error 33 on tektronix phaser 560
5 Suggested Answers
SOURCE: Tektronix 740 fuser
found solution, was the clutch on the accumulator shaft
Posted on Feb 06, 2008
faxman789
  • 297 Answers
SOURCE: I have a Tektronix 860dp
Fault 07,005.47 is a failure of the drum maintenance system. Having the printer repaired by a certified technician is strongly recommended because the printer's covers will have to be removed, and the printer partially disassembled.
Posted on Jan 16, 2009
  • 42 Answers
SOURCE: I have a Tektronic Color
hi,
the paper jamming problem is generic to most printer models of this capability. one way to circumvent this is to use a multimedia-tray while printing.
the reason is probably the two springs that hold down a silver metal pressure roller in the feeding unit. The tension is uneven due to old springs and the paper pulls crooked. If you follow the paper path in the fedder mechanism, you will see the roller I am referring to. The springs are at either end of this bar.
If you are good mechanically, you can replace the springs yourself, although they are a ***** to get back on (some disassembly required).
try this for details on doing it.
cheers
Posted on Jul 23, 2009
TimeDefensiv
  • 746 Answers
SOURCE: Tektronix Phaser 740 model 2740 Errors when
Change its setting with default settings, your issue will be resolve automatically.
Posted on Feb 27, 2011
Hi I have a TEK Phaser 560 Printer that displays Error 32-"Imaging unit error" after PC sends print command and 560 tries to start printing. I had problems to pull out the Imaging unit as well, because the...
There's a solenoid under the control board that actuates a stop for the cleaning blade shaft. The open cell foam the factory used to quiet the noise deteriorates with time leaving a sticky residue from the double sided tape.
Pick all the residue off and clean both the solenoid shaft and the metal plate. If you're concerned about noise, put some electrician's tape on the plate. But you might be going in for that falling off down the road. :p
Nov 22, 2009 | Tektronix Refurbished Phaser 560 Color...
Tektronix 540 error 32
Error 32 is most often caused by the cleaning blade clutch grease gumming up. Clean it completely with isopropyl alcohol and a lint free cloth and cotton buds. Re lubricate it with high temperature auto synthetic grease - make sure it has no mineral content.
Oct 07, 2009 | Tektronix Refurbished Phaser 560 Color...
Tektronix Phaser 840 Model Z840 shows error 08 001 44 215264
Check for broken Maintenance Drawer Guides, or the Printhead Cap/Wipe/Purge assembly is defective. (If it is for a Phaser 840)
Dec 05, 2008 | Xerox Phaser 8400 Laser Printer
I have a Tektronix Phaser 540 with an error code 32 when I powered it up. Can you tell me what this means?
This is from the 560 manual hope the codes are the same. The 560 manual states : Accumulator belt cleaning blade movement error.
1. inspect the cleaning blade{located on the imaging unit,along the bottom of the green OPC belt. Is it flipped up? If you cannot flip it down, replace the imaging unit.
2. Inspect the wiring harness leading from the cleaning board to CN18 of the engine control board.
3. Replace the cleaning board.
4. Replace the engine control board.
If the above info does not match your model call :
(800) 833-9200 Press 3
(503) 627-2400
Aug 21, 2008 | Tektronix Office Equipment & Supplies
Phaser 740 Printing Cyan only
The problem is usually caused by a faulty imaging device, specifically a bad cleaning blade.
Occasionally this error can also be caused by a sticking cleaning blade clutch.
In this case the grease that was used to lubricate the part becomes gummed up and the moving parts begin to stick and don't move freely as they are supposed to. This is especially common on these printers if they are not used heavily or have sat for long periods between uses.
Sometimes you can free up this gummed up grease by running the solenoid diagnostics several times over. You do this by turning off the printer and then powering up while holding buttons 1 and 3 on the front panel display. Button 1 is the exit button.
This will put your printer into service diagnostics mode. Page through the diagnostics menus until you come to the clutches and solenoids menu. Here you need to hit the start button, then scroll through till you see the test for the cleaning blade. Press start to run the test.
Let this test run for about an hour then hit the stop button and turn off and restart your printer.
If your printer is printing normally again then the sticky clutch is your problem and you will eventually need to remove it and clean off the old grease and relube it. I recommend a high quality lithium grease.
If your printer does not print correctly again after doing this test, then chances are that your cleaning blade on your imaging unit is bad and the imaging unit will need to be replaced. You can generally find them on ebay for a reasonable price.
This problem applies to both the phaser 560 and 740 models. The imaging units on both these printers are also interchangeable. So if you have a phaser 560 you can use an imaging device from a 740 and vice versa.
Jun 11, 2008 | Tektronix Phaser 740P Laser Printer
Phaser 560 "Jam at A"
Are there small pieces of torn paper on the rolls anywhere... Had that happen
Mar 18, 2008 | Tektronix Refurbished Phaser 560 Color...
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Tektronix 740 fuser
Nov 06, 2007 | Tektronix Phaser 740P Laser Printer
Tektronix Phaser 850 Service Fault 13.019.40
Most likely a bad print heat. One of the ink heaters is overheating.
Oct 08, 2007 | Tektronix Phaser 860DP Thermal Printer
Open Questions:
527 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Vuk B
Smithmkt
Smithmkt
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
