Mitsubishi WD52525 Brightness
Change lightbulb, change 4 caps. one of them was bad. tv looks ok. but, Im not satisfied with the clarity of the picture on this set. My mother is not a technician and she even can tell that something is wrong with the lack of clarity in the picture on this tv. We are receiving over the air hd signal, but the tv image still looks opac, dull, and without BRIGHTNESS. If there is something I can do to bring back this tv brightness and vivrant colors of this set?? the primary colors of the tv are already tone in.
thank you
David O.
  • jammin dave Mar 07, 2008
    Thanks for the suggestion. My next step would be cleaning the dust out of the glass projection fixtures. Hopefully helps.
    Thanks again.
  • 116 Answers
Usually a bad lamp. If the lamp you replaced is new, then cleaning the internal mirrors (especially the small triangular one) and clean the projector assembly as well. The lamp ballast supply may be weak as well, but I seldom see this.
Posted on Mar 05, 2008
Have a Mitsubishi Model WD-62528. Picture is dull and colors anr not viberant. What can I do to get the great picture I had. Changed light about 4 months ago
I notice the same thing with my 62" after several years -- the problem was dust on the inside if the screen. Take it off (have someone help you - it's big and bulky) and carefully clean the dust and also in my case cobwebs from inside the encluse - this made a huge difference for me in picture brightness and clarity.
Nov 25, 2011 | Mitsubishi Televison & Video
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The tv has a haze look to it. Looks really washed out.
Thats usually caused by the front small mirror which gets dusty and the image will get very dull and washed out. Cleaning the small front mirror will restore the clarity and bright colors again. use just a damp cloth with water then dry thoroughly. If you dont know how to gain access to the small mirror up front you can get the service manual for that model emailed from the following link, It has the disassembly instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/wd52525-dlp/cName/mitsubishi
Dec 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Rear projection tv picture quality loss
most of these sets have 3 lens for the three picture tubes inside and also a mirror---if it has never had the lens cleaned they could be dusty and this will diminish the brightness and clarity of your picture---if real dirty the picture will look washed out------most of these sets you can remove the back cover(unplug set first) and gain access to the lens ; clean them with a lens cloth or a paper towel with glass cleaner.
Aug 16, 2009 | Televison & Video
Green screen
sound like a DM or FMT board failure. this is not the 4 cap blinking green light problem. check out
www.tv-techs.com
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Bad Mits capacitors
You can get the full service manual at the following link that will show you how the chassis is removed and then its just reverse the proceedure. Heres the link.
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD52525 DLP TV
Yes, this can happen and there also are fuses that needs to be changed(F9A09) and caps C9A37,38
Mar 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Caps cause dim Picture faulty capacitor issue in the WD-52525 does seem to be prevalent at the 3 yr mark. At the bottom of this long-winded comment is a link to another discussion forum similar to this one where we obtained the service manual, chassis replacement manual, and encouragement to attempt the repair ourselves. My husband and I are not experts by any means, but my husband did have the tools from previous electronics projects to solder. So we took a chance on looking for bad caps. And I am here to say that I’m so glad we did because there were 2 obviously swollen caps that were easy to replace. The picture is now even better than when the problem first occurred since we dusted the mirrors and screens while we were in there. NO WINDEX. Just a dry micro-fiber cloth did the trick. We'll probably do that annually going forward.
According to descriptions from several people, the symptoms and degrading image due to capacitor failure can take various forms. In our case, we had a lamp blow out 2 wks before the TV died. And I do mean blow out, not burn out. We didn't get any lamp replacement warning. It flat out blew the 1-yr old bulb to shards of glass inside the casing. We replaced the bulb with a brand new one like good stewards of a DLP HDTV should do. A mere couple of weeks later we watched the image degrade over the course of an hour through various stages until the new lamp simply wouldn't light anymore and there was a solid black screen and solid red lamp light even though the lamp itself was fine. The trouble-shooting diagnostics (pressing MENU and DEVICE buttons on the front panel) gave the 3-4 code indicating a lamp abnormality. But ultimately the problem was solved by replacing the C9A37 & C9A38 caps (both are 10V 3300M-M 105C). We did not have to do any repairs on lamp or ballast components. The cost of 2 new capacitors from Digi-Key including shipping was about $14.50.
Some folks have stated that they were able to do the repair without removing the power supply chassis from the back of the TV. That was not the case for us. It was a bit intimidating at first. But we disassembled everything, labeling as we went, so we could freely inspect and access all boards on the power supply. There are some tiny, very hard-to-reach connections between the power supply and the ballast. For this reason, I also recommend disassembling those ballast components from the frame. They're simply too fragile to force in a very tight space when reconnecting.
Lastly, I am still pleased with this TV. The color and clarity can not be rivaled in my opinion. Even after having gone through this, compared to the problems reported in some of the other threads on issues with whatever other brand name or model you pick, this is a relatively easy repair that can be DIY. This was why we went DLP in the first place. And it is why we will probably remain DLP fans until they aren't made anymore. But next time, we’ll go with an extended warranty for sure!
I do wish Mitsubishi would at least acknowledge the issue. I don't even expect any reimbursement, replacement, refund or anything like that. I'd just like to know that THEY know there's a simple problem to resolve and that they're doing something about it.
http://www.avsforum.com/avs-vb/show...=418307&page=84
good luck
please mark the post with a fixya
Feb 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
