Question about Konka K1938U 19" TV
Tv problems Hi, I have had problems with my TV reception, a cable had been chewed though by bird and since this was fixed and I re-tuned the TV. The channels do not tune on the correct channel numbers and I cannot get channel 0 on which I can use to play my video? (Model K2139E3) Please can you help? Many Thanks Caroline Mckenna 0402 693 494
    Brigadier General:
  • 6,966 Answers
I am assuming that you are using cable and not an aerial/antenna.
On your concern "...channels do not tune...correct channel numbers...", it is possible that when you re-tuned the TV your setting was set to AIR or STD, try to re-tune again but this time pls verify that you are in CABLE mode. If on the other hand you are using aerial/antenna, then it is the other way around.
Channel 0 would automatically be your Audio/Video (which is where your DVD/VCR is connected). If you re-tune, chances are that Channel 0 ) would be back. To be on the safe side, pls power on likewise the DVD/VCR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Mar 04, 2008
How do I keep it on Digital? When I try and turn the channel, it goes to Video 1. It says Digital channel signal strength is low.
How to fix digital TV reception problems - Simplify Digital
www.simplifydigital.co.uk > Guides
SimplifydigitalJul 11, 2014 - This handy guide will help you fix simple digital TV reception issues with Freeview, satellite and cable TV set top boxes. ... If you're suffering from poor digital TV signal, it may be possible to fix reception issues quickly, at home. ... We're here to run you through how to fix TV ...
Digital television transition in the United States - Wikipedia ...
Dec 26, 2015 | Televison & Video
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
Can a toshiba 28z07b be digitally tuned
Your TV set has a 181 Channel Tuner and 100 Programme Positions..
Over the air signals (analog and digital) are free but require an special antennas for Digital reception and reception depends on your where you live and other factors.
Additionally Cable and satellite signals require you to connect a cable to your
TV tuner and a subscription and cable box for premium channels including Digital channels..
While all l TV tuners have the ability to receive over the air TV signals,
not all tuners can receive high definition (HD) signals. In North America, all
over-the-air TV is now broadcast in digital quality (ATSC).
ATSC is the over the air HDTV standard for North America and is currently available
in over 200 cities in the United States.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 29, 2011 | Toshiba Televison & Video
Hey im Ryan, Just wondering how to tune a AWA 32 inch tv?
Hi, Many of these TV sets have auto- tune built in the sets. If you are still using antenna you will have to turn the antenna for better reception. If you have cable or dish you will not need to do anything. The set top box will do it all for you.. I hope that helps you.
Jun 08, 2011 | Grilling
MY NEW HAIER 7" TV SAYS "NO DATABASE"! AND WHEN
Don't throw it away just yet. It's still under warranty so returning it would be far better than throwing it away ;)
As you can tune the cable channels OK, I suspect there is a problem with the reception from the antenna and the signal strength is too low. Please can you answer the following simple questions so that I can help you to solve this problem
1. What antenna are you using - indoor/rabbit ears or outdoor/roof antenna?
2. Do you have a good reception on another TV connected to the same antenna ?
If you are using an indoor antenna, try moving the TV to another location to see if you can get a better reception.
Please let me know the answers to the above questions. I will then be able to assist you further.
Regards,
BElectric
Jan 22, 2011 | Haier HLT71 7 in. Portable TV
Problems on the freeview 21inch Tv Teknica from Tesco was working when we bought it 2 years ago cannot get all the channels and poor reception re installed channels many many times but does not maintain...
you may want to try changing the coaxial aerial cable that feeds the tv, these can go faulty. also if you are running a series of tvs off one aerial, you should be using an aerial booster, other wise you will get a signal drop (as displayed on your tv).
If these small things don't cure it, the set requires replaceing as the tuning card is knackered
Jan 16, 2011 | Audio Players & Recorders
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
My Akai LCT42Z6TM TV does not have a coaxle
A converter box isn't going to fix this problem.
Your TV is a Monitor. It doesn't have a built in tuner. That's why it doesn't have a Cable/Ant coaxial port.
The TV needs a cable box for tuning or some other outside source box for receiving signals.
Are you using cable from the cable company or an antenna for reception?
Apr 23, 2009 | Televison & Video
Konka K1938U 19" TV Logo
237 people viewed this question
Top Konka Televison & Video Experts
Arnel
Arnel
matt martin
matt martin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
