Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Pioneer DEH-P2900MP head unit
Installed it on my 2000 cadillac deville with onstar interface adapter using the rca jacks for front and rear speakers but volume is really low. cant hear it very well until volume level 25
There is no power from the rca jacks. Option 1; connect the speaker wires directly. Any aftermarket auto manual (Hayes, Clymer) with wiring schematics will let you know what wire is what in the dash. Option 2; RCA jacks output to an amplifier. There is no power coming from the RCA jacks. They have to be used with the amp. If you chose to use the normal speaker wires, be aware that these radios do not like stock speakers or wire. If you take the time and money to replace all of it, the head unit will last much longer. If you choose to use an amplifier, it will burn out fast unless you replace the speakers and wires immediately.
Posted on Apr 22, 2008
How to get rear speaker signal from aftermarket stereo
You can fade front to rear in the menu but its not switched it might be fully faded to the front
Aug 31, 2014 | Pioneer Deh-X6600bt Car Cd Receiver...
I need to know what wires are for what on my Pioneer Head unit model number deh-p2900mp.
black=negativered=live yellow is for memory witch should be conected to a permenent live blue is for electric areal and the rest are for speakers
Apr 04, 2011 | Pioneer DEH-P2900MP CD Receiver...
I Have a 2000 Impala without onstar, i tried to replace the in-dash radio with an aftermarket one, i bought an 80$ wiring harness for my car because of a chime and it came with 4 rca cables along with the...
The four RCAs are for the speaker outputs.They plug into the rear of the Pioneer unit (front and rear outputs). Also, you didn't mention the model number of the wiring harness (necessary to properly diagnose the situation) but, some these units have one or two philips head dials to adjust the volume of the stereo and the volume of the chime. These dials may be on the side of the unit or, oyu may need to open the casing to see them.
Jan 26, 2011 | Pioneer DEH-3900MP CD Player
Wiring for pioneer deh-p2900mp
Orange - 12V constant
Red - 12V switched (acc)
Black - Ground
Green - Left Front +
Green/Black - Left Front -
Grey - Right Front +
Grey/Black - Right Front -
Green/red - Left Rear +
Black Green - Left Rear -
Grey/Red - Right Rear +
Black/Grey - Right Rear -
Oct 22, 2009 | Pioneer DEH-P2900MP CD Receiver...
Need speaker wiring diagraham for pioneer DEH-2900 MP
You can follow this link for the User manual
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players/DEH-P2900MP?tab=D
Apr 04, 2009 | Pioneer DEH-P2900MP CD Receiver...
Hook an ipod to Pioneer DEH-16
The RCA jacks on the rear of the head unit are rear pre-amp outputs. (google it if you need an explination on what purpose they serve or see the installation guide) With that said, I am able to play my mp3 player through them but since they are 'rear' pre-amp outputs my mp3s only play on the rear speakers. see this post for more...
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=45149&query.id=194369#M45149
installation manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/35572505Installation%20Manual%20DEH-1600.pdf
owners manual:
33399012operation%20manual%20deh-1600.pdf
Mar 15, 2009 | Pioneer DEH-1600 CD Player
No sound with iPod Adapter CD-IB100II in the DEH-P2900MP
on the radio and the adapter their is a spot for the cord that connects the two the ends have different colors on them it should be purple and black just make sure the colors are matched up if they are off it will still read all the info and say its playing but no sound will come out
Oct 15, 2008 | Pioneer DEH-P2900MP CD Receiver...
Installing a DEH-P31000 into a 97 Cavalier
grey (-) Driver front
tan (+)
dark green (-) Pass. Front
light green (+)
brown (-) Driver Rear
yellow (+)
dark blue (-) Pass. Rear
light blue (+)
yellow (+) Battery
Black (-) Ground
hope this helps.
Mar 24, 2008 | Pioneer DEH-P2900MP CD Receiver...
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
288 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
