Question about Toshiba Satellite M65-S9092 Notebook
Power Issue The computer worked fine 3 days ago. I packed it up (battery was fully charged) and took it to work, but never actually used it. I brought it home and it sat in its case for 2 days before I decided to hook it up again. Upon hooking it up (external monitor, ac power, usb mouse/keyboard, and internet cable) I tried the power button. Nothing happened. I disconnected everything except the power cord, and still nothing. After I disconnected the power cord, the power button would light up, but nothing else would happen. No booting up, nothing on the screen, cooling fan not operating, nothing. If I press the power button again, it shuts off. Also, if I plug in the cord while its "on", the light turns off.
  • 520 Answers
Sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Posted on Mar 04, 2008
Troubles Turning Camera On
What kind of camera is this? I suggest calling the company such who will take time on the phone and work with you to fix the issue. Didn't have the same problem but have a Nikon and they assisted me over the phone almost an hour working with me to solve the issue.
Mar 25, 2017 | Cameras
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
Flip ultra hd not charging
I had the same problem, but it seemed to be a bit more sporadic. I'd occasionally get the "Charging Paused - Check Battery Pack" error. The battery pack itself looks a bit strange, since the white plastic covers the bottom, right side and it seems that there is no possible way for the battery to make contact with the camera. However, I saw the following suggestion on another site (which the poster claimed came from Flip technical support), and this technique worked for me:
1) remove the battery pack from the camcorder
2) connect the camcorder to a powered USB port on your computer
3) when the "Connected" indicator comes on, insert the battery pack into the camcorder
4) safe eject your camcorder from your computer
5) reconnect your camcorder to your computer
6) the battery pack should now begin to charge within the camcorder
May 20, 2009 | Pure Digital Flip Video Ultra Camcorder
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Help
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 25, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
IBM T30. Battery will not charge.
if your laptop is working fine , plugged in the power, you are hving a problem with the battery pack. If you recently bought this, contact the resseler to replace the pack.
May 02, 2008 | IBM ThinkPad T30 2366 Notebook
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon S2 IS won't turn on with rechargeable batteries??
I would let them charge til you get an indication that they are done. TV remotes require very little power to operate, while digital cameras need a lot, so that's why the batteries would work in the remotes though not fully charged.
Jun 16, 2007 | Canon PowerShot S2 IS Digital Camera
C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Kiwi-Mark
Jun 05, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Toshiba Satellite M65-S9092 Notebook Logo
200 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
