DENON AVR 2808CI NO SOUND FROM CENTER CHANNEL SPEAKER
I have tried to use the AUDYSSEY three times and still have problems. The Audyssey sound comes out of all my speakers when running. The recievers speakers all work except the Center Channel Speaker. Actually, I only have 3 speakers hooked up to it, 2 main and a ctr speaker. I noticed that the display on the receiver shows LF and RF but not CTR. No sound from my CTR Speaker! Also how do you Manualy set the receiver??? The manual sucks and the remote is worthless at best! HELP!!!!
5 Suggested Answers
SOURCE: center speaker no sound
had the same problem and SOLVED it.. the problem is caused by bad solderjoints on the pcb with the pre-out connectors on it. the solution is to take this pcb out and inspect it visually for signs of loose/oxidized solderpoints - indicated by a faint gray 'ring' near the soldered wire. just resolder and there you go! an amp as fresh as on its day of birth.. enjoy
Posted on Oct 28, 2008
SOURCE: Onkyo 875 Audyssey will not detect
no solution from me but just to say i am having exactly the same problem - did you get anywhere with yours?
Posted on Dec 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: Audyssey vs Direct switching on Onkyo SR606
Audyssey is the licensed feature this receiver uses for room and dynamic equalization. It sounds like the Audyssey process is activated. The manual says the Audyssey indicator "flashes during automatic speaker setup".
Has this unit ever worked or are you still setting it up?
Posted on Feb 10, 2010
mlapres
  • 757 Answers
SOURCE: This may not be an
If it sounds normal, then yes leave them as they are.
But there may need to be an exception made.
The distances are set the way they are for the proper advance or delay in milliseconds of the sound arrival at the listening position.
The system calibrated your speaker settings based on how each channel's frequency responses measured at the listening position. Room acoustics and channel positioning greatly affects this. The settings it made in the system can be a best case scenario compromise that MAY not be good for your surround speakers as it can be delivering signal to them that they were not designed to handle; in which case it is best to increase the crossover value of those speakers.
Posted on Mar 29, 2010
I have a buzzing coming from my suuround sound speakers
Check to make sure your audio cables aren't touching any power cables. This will ensurethat you aren't getting signal interruption from latent overflow. Next, make sure you volume levels are correct. You could be overdriving the channel with too much output. Finally, make sure your speakers and/or source aren't next to anything with a strong radiation signal such as a transmitting device (2.4 GHz phone or microwave). Let me know if you've verified this and then we'll troubleshoot further. This sounds like interference to me.
Jan 02, 2015 | Onkyo HT-R2295 3D Ready A/V Receiver - 7.1...
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
Jan 01, 2015 | Marantz Audio Players & Recorders
Denon instructions
I don't have this particular model but I have owned 2 Denon receivers and I suspect yours is similar. On my Denon there is a manual speaker set up with a test tone for each channel. This will allow you to boost or reduce the DB level of each speaker individually. I would do this while sitting where you do while watching TV. be sure:
1. The receiver is in surround sound mode to do this.
2. My receiver also came with a microphone that can be plugged into the receiver to allow automatic level set up through what Denon calls the "Audyssey" set up. The equalizer setting are also located in the "Audyssey" settings.
You might check your manual before you begin.
Sep 07, 2014 | Denon Avr-4802R-Av Receiver-7.1 Channel
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
Feb 09, 2010 | Onkyo TX-SR606 Receiver
Voice volume is low compared to background music volume on AVR-2808CI
Could be a number of things.
Most likely your surround sound mode. Some people dont like Dolby. Try to switch to 5 channel stereo.
Other option is to turn the center channel speaker channel volume up. Voices and dialog come from the center channel speaker in Dolby modes. Post back if you need instructions.
Please rate my solution.
Nov 30, 2009 | Denon AVR-3805 Receiver
Denon avr 2308 no subwoofer operation
is the sub in speaker set A and sub in set B?
that was my problem on Denon DRA-455 with Eltax Linear 6.5
May 29, 2009 | Denon AVR-2308CI
No sound playing through microphone
The microphone included with this receiver is for audio adjustments only. That's the "Audyssey Laboratories' MultEQ® six-point auto setup and room calibration system". You cannot hear yourself speaking through the microphone.
Nov 26, 2008 | Denon AVR-1905 Receiver
233 people viewed this question
 Grubhead
Grubhead
