Question about Sony Cyber-shot DSC-S700 Digital Camera
Format Error in Sony Cybershot
I have this Sony Cybershot camera. I recently inserted a Sony memory stick of 1 GB into it and when I turn on the camera, it gives "Format Error"
The camera works fine with Internal memory. Please advise on what to do.
Thanks in advance,
Janet
When I insert the Memory Card, it shows "Format Error"
There is no tools feature on the sony...select the 1st button lower right...all touch screen features appear...select menu in lower
left...select setup...camera 1 will display...select down arrow
twice until you reach format, the select...that should reformat
the memory...
Posted on Apr 07, 2008
  • 55 Answers
It could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Posted on Mar 25, 2008
Hello
i have the same problem as mpandi
and to you solutions:
...when i format my memory stick,all the pictures i made will be lost or?
thanks for help
or in other words spoken; how cani save pictures i made , when suddenly "format error" appears on my camera display?
Posted on Oct 09, 2008
4 Suggested Answers
mcomijohns
  • 477 Answers
SOURCE: dsc-s700 format error
If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
SOURCE: Format Error in Sony Cybershot
I think I solve the problem wih my sony camera.
After readin almost all posts on this problem I lost hope to save my photos from that "Format error" stick. So first I start to format the memory with the camera, after 5-6 minutes it says everything is formated. I restarted the camera but again there was a memory error message, but this time the blue screen has gone and I can see where lens are pinting. After that i start the format function again on my camera, but after a few seconds (just at the moment when it starts to format) i took put the batteries. When I put the batteries again the memory stick pro duo was empty. So I downloaded a program for memory restore (Rescover my Photos) Here is a link with program with C.. R... A.. C... K... http://www.2baksa.net/news/27705/
So that program found all the pictures and the movies that were on that stick. You must take a deep scan to the memory and have a full battery life to take out the pictures. So, good luck.
Posted on Sep 15, 2008
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Posted on Jul 07, 2010
How to fix "reinsert memory
Welcome to FixYa.
There 3 possible causes why do you received an error message " reinsert memory card"
Cause
1 The inserted Memory Stick media is not supported for use with the camera.
2 The terminals on the Memory Stick media are dirty.
3 The Memory Stick media is damaged
Resolution
1 Ensure you are using the supported type and capacity of Memory Stick media for use with the camera
2 Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up
3 Use different Memory Stick media
I hope this steps wil help you to resolve your isuues.
Thank you for using FixYa.
Apr 04, 2011 | Sony Cybershot DSCW310 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
I purchased a Sony cybershot DSC- S930 and inserted the Lexar memory stick (supposedly compatible with a sony camera) and upon turning the camera on there is an error message stating there is not internal...
The camera does not recognize the card because
1. Card not compatible
2. Camera cannot handle such a large capacity.
3.Card not inserted correctly.
Maybe a recent firmware update can address the 2nd limitation.
Hope it helps.
Sep 11, 2009 | Sony DSC-S930 Digital Camera
Sony
there might be a problem with the file system you are using with with memory stick..insert it into card reader > format it with fat 32 file system..and insert it again to solve your problem.....if problem still persist .insert your memory card into mobile and goto your memory card > now select option > there you will see format memory card > so it will format your memory card with correct file system that your mobile wants.....
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Dsc-s700 format error
Mar 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Jan 02, 2008 | Cameras
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Nov 05, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
933 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
