Televison & Video Logo
Posted on Mar 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i get power supply module for viewsonic lcd tv model N3260w
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Mar 02, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2956555
Points
33084
You can buy power supply board/ module of Viewsonic N3260W from Shop Jimmy on special price, $65 only.
Thanks.
I have a Viewsonic N3260w TV, the Power Indicator light is flashing red continually, but the remote wont start the tv, I have changed the batteries, turned the tv on and off, but the tv still wont...
The problem of your tv is in the power supply. In order to find the power supply of your tv ,you should follow the ac cord. But first you should unplug the unit and open the back cover of your tv there you will find the power supply, try to check the capacitors, it is cylindrical shape and has a plastic cover. Try to observed if their is a wet mark or oil mark that spread in to the pcb then replace it. But when replacing the capacitor you should observed the polarity of the capacitor and replace it exactly the way you pulled it out.
Power light flickers no other sign of power n3260w ?
If you get a flicker of power light then your problem is in your power supply, I would check for bulging capacitors and replace, if you don't find any then replace power supply, you can check places like shopjimmy.com, or discount-merchant.com or with an s, vancebaldwin.com
3answers
My viewsonic n3260w
You need to find out if it is putting out the 24vdc needed by the backlight inverter board, you may have bad shorted out inverter board that may have taken out the fuse, you need to do some probing.
Power supply pin out: http://www.fspgroupusa.com/images/specs/FSP228-3F01_SPEC.pdf
Power supply: http://www.shopjimmy.com/fsp-fsp228-3f01-power-supply.htm
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
1helpful
2answers
2helpful
2answers
I have the above tv viewsonic n3260w and lost the picture but kept the sound any ideas what may have happened
Ur LCD inverter board is dead.This board help to get the backlight to the LCD screen to make the Tuner board get the tv signal throught.Replaced this LCD inverter board will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
2answers
ViewSonic Mod# N3260W VS11436 1M
I do not know the exact value but if you trace out the copper trace from the rectifier output, it should go to the first filter cap and then there will be an inductor and filter cap after that, you can figure out the voltage rating from there. You can get the parts here: http://www.shopjimmy.com/catalogsearch/result/?q=ViewSonic+N3260W
Look here about caps: http://en.wikipedia.org/wiki/Capacitor_plague
Pictures of the power supply will help. [email protected]
10helpful
2answers
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
1helpful
2answers
New Power Supply
Saadi2,
In my line of business I have purchased over 20 of these units. The power supply is listed on the Viewsonic Store web-site. Part# is B00005305 cost is about $65.00. Being a Tech myself I went the route of replacing individual parts but had no luck. Take into consideration time to repair its cheaper to by the replacement board. You can always fix the damaged board later as a back up.
Good Luck, OTBMAN
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
