Question about Lands Phones
Ring Tune compatability
Phone supports MP3 files to play as Ring tone. I took a song on my computer and cut it using a program I found online. The file is 10s long and very small, both my laptop and phone can play the clip but my phone will not use it as a ring tone.
Sony Ericsson 580i.
Error message received "Cannot set this file as a Ring Tune"
  • Jsly Mar 04, 2008
    Nvm, I figured it out. thanks for the link but apparently my retailer (Rogers Canada) impelements a file protection on files that can be used as ring tunes. Basically forcing you to buy them. but I found another thread with the solution here :http://cellphoneforums.net/sony-ericsson...
  • 121 Answers
You can try this link for mp3s these should work
http://www.phazemp3.com/
Posted on Mar 04, 2008
Hey my service provider of vodafone i want to
caller tunes are not network dependant, they are phone dependant. you must have a phone that is MP3 compatible. download the tune to the phone, in your contacts edit a contact and choose the song as the ring tone. check phone manual to how to do it.
Oct 20, 2013 | Video Game Consoles & Games
I have a samsung s3100 i cant play memory card songs on the music player. Please help... I really need ur help this phone is wack.
Good Day!
i have checked your phone online. your Samsung s3100 can only support audio files with these formats. .mp3, .wav and polyphonic ring tones only. So please, try downloading audio file with these file extension formats or you can download a software than can convert audio file that suits your cellphone. for example: the lazy song.mp3 or the lazy song.wav
i hope this helps.
Jul 20, 2011 | Samsung Cell Phones
The ring tone is defaulting to generic Nokia tone when I have set it to an mp3 song that is loaded on the phone. The songs play correctly in the music player, but the phone won't ring with the set tone.
Your MP3 file may be too long in duration (try cutting it down to less than 10 seconds and try again), the file name may be too long (try renaming it on the desktop as ringmp3.mp3 and transfer to phone), or the MP3 may be recorded in a bit rate that is too high for the phone to support as a ringtone (transcode again to a lower bitrate).
Aug 19, 2010 | Cell Phones
How to set mp3 song from memory card as your caller tune
I think that there have been some mistake.....Caller Tune means the ring-tone which is hearing by someone who is calling you.So you cannot set the caller tune yourself, it is provided by the Sim service provider.Here However, Ring-Tone means the tone which you are hearing when someone is calling you.We can easily set this tone by using....Menu......>Profile...........>Ringing tone setting....Set the tone what you wish............................
Aug 10, 2010 | Nokia N73 Cellular Phone
I Keep getting "playback error" "format not supported" on lgcf360
Hello All, I think I may have a solution for the 'Playback Error'problem with the LG CF360. Below, I have put the steps that caused my phone tohave the error and then the steps I took to get rid of the error. Firstly, my CF 360 worked well for hours of playing songswithout any error. Then, after I did the following steps, the error happenedover and over.
  • I pushed a mp3 ring tone via blue tooth to the phone with the SD card in. It saved the ring tone in the SD card, but I wanted it on the phone in case the card was out, it would still ring.
  • I took out the SD card and pushed the same file to the phone, so it would save on the phone and not the SD card.
  • I also pushed another mp3 to the phone.
Then, the "Playback error" happened intermittently every fewminutes. This may have been caused by either
  1. The phone's library of mp3's being corrupted because of the same file in two locations, or
  2. The phone's physical memory getting too low to effectively play music.
Here are the steps I took that got rid of the error.
  • Delete the duplicate mp3 from the SD card
  • Move all music mp3's to the SD card and off of the phone.
  • Move some pictures to the SD and off of the phone.
  • Shut off phone
  • Take out SD card.
  • Turn on phone and try to play a playlist of songs that were on the SD card (causes the phone not find the file and update the music library)
  • Put in SD card while the phone is on. (causes the phone to re-build the music library).
After I did this, I have played mp3's for hours without anyerrors at all, just like before. Either I had too much stuff on the phone orthe music library was not correct causing the crash. I hope it helps. Mike
Aug 14, 2009 | LG CF360 Cell Phone
Us cellular LG UX830
wut i did was : First i downloaded this program named audacity so u can cut chunks of the song. then i downloaded another program called Switch converter cuz this particular phone only plays songs on mp3 or mp4 format. unfortunately u can only cut up to 278 kb which is about 18 seconds of the song. but that's wut i did and it works just fine .
May 05, 2009 | LG Vu CU920 Cellular Phone
Ring tone
1. to set mp3 ring tones...
copy any mp3 file to phone ( via cable or bluetooth )
go to multimedia = go to mp3 = now play the song you want as tone,
when song is playing, select options, and select = set as ring tone
DONE and smile......
2. to set Default sound ring tones...
go to menu = my stuff = sounds =
browse the sound files when you like one , select options, and set as ring tone.....
Done and smile again... hope this helped...
May 13, 2008 | LG KG800 Cellular Phone
Ring tone problem
MP3 format file are for you to listen to.
.mid, .aac, and .amr file extentions are ring tones.
You can download ring tones from:
http://www.zedge.net/
Jan 07, 2008 | Nokia 5300 Grey Cellular Phone
In call tune
go on to mp3 player thing select a song go on optiions n set it as ur ringtone
its simple
Dec 27, 2007 | LG Shine KE970 Cellular Phone
Unsupported File, Ring sytle
is it all in your memory card data,, doesn't show up in media aside from mp3?
Jan 25, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
107 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
