Question about Sharp AR-M237 Copier
How do I change the drum on a Sharp AR-M237?
I’m a student at a small university in the middle of no where. The drum on our Sharp AR-M237 needs replaced and there aren’t any companies that will work on it. The only one is Xerox, and they refused because it is not their brand. I am pretty handy with fixing things so I got nominated. I am sure I can “figure it out” but I would rather do it right the first time and avoid getting straight F’s for breaking our only copier. Any help would be greatly appreciated.
BTW, is it sometime possible to just clean the drum vs. replacement? If so, what is the best way to do this?
Thank you very much!
  • jman71 Mar 04, 2008
    Hi Andy, yes the print quality is very bad. Has pleanty of toner. Then dean mailordered a drum, so I have it ready to go. Just need to know the best way to swap it out. Thank you very much in advance :)
Hi, i assume you have a drum to replace it with?. Can't really clean them as they are very sensitive. Why does it need changing, your copy quality is effected?. It is a faily straight forward procedure.
Let me Know
Andy
Posted on Mar 04, 2008
I am also changing a drum and after I changed the drum the copies began to get lighter and lighter, why is this? Also does direct light affect the drum during the installation process? I followed the instructions why would my copies be so light I can't read them?
Thanks
Jim
Posted on Jul 10, 2008
  • 29 Answers
Its better to replace the drum to obtain the good quality copy of your copier.the first thing to do is open the front cover.then pull out the toner/developer unit.and after that you can now remove the drum unit.To instal the brandnew drum unit just follow the instraction in the manuals.ok
Posted on Mar 05, 2008
I DO NOT HAVE A CD TO DOWNLOAD MY SHARP AR-M237
Hello
You may find drivers in this link
good luck
Nov 20, 2010 | Sharp AR-M237 Copier
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
On a sharp arm 257 can you a drum unit or just blade and drum
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Jun 03, 2009 | Sharp AR-M237 Copier
I need to change the IP for my ar-m237
Try to increase the router range to include the ar-m237 or change the copier to a lower IP address within the range of the router.
Jan 03, 2009 | Sharp AR-M237 Copier
Sharp ar-m237 copier
Direct light can effect the copies. Your unit may also need developer as well. If the developer is low or gone out of the unit, light copies will appear as well.
Jul 10, 2008 | Sharp AR-M237 Copier
Drum change
Ok first their will be a blue screw right aboive where the toner goes in unscrew this remove the dv unit open the left door slide the drum out on the front of the drum there is a plastic piece turn to release the drum then on the top of the drum their are two screw to remove the m/c unit slide it and remove it then two more screws to remove the drum blade.This machine takes ar-271 dr and ar270bl it will also need devlopor at the same time ar-271 dv.Then when done you will need to set the dv pound asrtic clear astric 25-02 start then counter need resetr in 24 5,6,7 and 10. Good luck this is not a job 4 a first timer.
Mar 05, 2008 | Sharp AR-M237 Copier
Sharp AR-M237 Copier Logo
816 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
